Introduction
This guide contains the necessary steps to replace the HP Pavilion dv6500 trackpad.
Ce dont vous avez besoin
Remove fifteen 7.0mm PH0 screws.
Remove five silver 4.0mm PH 0 screws inside the cavity for the battery.
Gently lift the plastic panel on the top of the laptop at the divide until the two ribbon cables and cable leads are visible with their ports on left side on laptop.
Using the size 5.0mm hex tool, unscrew the 2 brass screws located near the RAM cards under the laptop.
