Aller au contenu principal
HP Pavilion dv6t-1200 Disk Tray Replacement
Ce dont vous avez besoin
  1. HP Pavilion dv6t-1200 Disk Tray Replacement, Disk Tray: étape 1, image 1 de 2 HP Pavilion dv6t-1200 Disk Tray Replacement, Disk Tray: étape 1, image 2 de 2
    • Locate the small hole on the right side of the disk tray next to the button.
  2. HP Pavilion dv6t-1200 Disk Tray Replacement: étape 2, image 1 de 2 HP Pavilion dv6t-1200 Disk Tray Replacement: étape 2, image 2 de 2
    • Extend the paper clip into a straight line and insert it into the disk tray hole located next to the release button.
    • When the disk tray is removed, make sure to clean the general area with canned air.
  3. HP Pavilion dv6t-1200 Disk Tray Replacement: étape 3, image 1 de 1
    • Flip the laptop to the other side and remove the four screws on the bottom of the disk tray using a Phillips #0 screwdriver.
  4. HP Pavilion dv6t-1200 Disk Tray Replacement: étape 4, image 1 de 2 HP Pavilion dv6t-1200 Disk Tray Replacement: étape 4, image 2 de 2
    • Remove the metal plate and locate the bottom right tool for the disk tray.
  5. HP Pavilion dv6t-1200 Disk Tray Replacement: étape 5, image 1 de 2 HP Pavilion dv6t-1200 Disk Tray Replacement: étape 5, image 2 de 2
    • Replace the motor piece that is being held and reclose the device.
  6. HP Pavilion dv6t-1200 Disk Tray Replacement: étape 6, image 1 de 2 HP Pavilion dv6t-1200 Disk Tray Replacement: étape 6, image 2 de 2
    • After replacing the motor and the placing the metal tray apply a good amount of WD40.
    • Once all completed the disk tray should be working smoothly.
Daniel Pelayo
Membre depuis le 10/05/21
210 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 11-21, Grodsky Fall 2021 Membre de l'équipe CSU Los Angeles, Team 11-21, Grodsky Fall 2021
CSULA-GRODSKY-F21S11G21
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 275
