Aller au contenu principal
HP Pavilion dv7-1285dx Back Plate Replacement
Ce dont vous avez besoin
  1. HP Pavilion dv7-1285dx Back Plate Replacement, Battery: étape 1, image 1 de 1
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx Back Plate Replacement, Back Plate: étape 2, image 1 de 1
    • Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
    • These screws do not completely detach from the device when unscrewed.
  3. HP Pavilion dv7-1285dx Back Plate Replacement: étape 3, image 1 de 2 HP Pavilion dv7-1285dx Back Plate Replacement: étape 3, image 2 de 2
    • Use the plastic opening tool to lift up the back plate and set it aside.
Chris Apple
Membre depuis le 04/14/14
239 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 12-34, Maness Spring 2014 Membre de l'équipe Cal Poly, Team 12-34, Maness Spring 2014
CPSU-MANESS-S14S12G34
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 14
Total : 1,527
