Aller au contenu principal
HP Pavilion dv7-1285dx Keyboard Replacement
Ce dont vous avez besoin
  1. HP Pavilion dv7-1285dx Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx Keyboard Replacement, Keyboard: étape 2, image 1 de 2 HP Pavilion dv7-1285dx Keyboard Replacement, Keyboard: étape 2, image 2 de 2
    • Using a Phillips Screwdriver, remove the four Phillips M25x3.0 head screws.
  3. HP Pavilion dv7-1285dx Keyboard Replacement: étape 3, image 1 de 2 HP Pavilion dv7-1285dx Keyboard Replacement: étape 3, image 2 de 2
    • Using a plastic opening tool on both the left and right sides to remove the upper portion of the top plate.
    • Orient the device such that it’s partially opened (a little less than a 45 degree angle) and the hinge faces up.
  4. HP Pavilion dv7-1285dx Keyboard Replacement: étape 4, image 1 de 2 HP Pavilion dv7-1285dx Keyboard Replacement: étape 4, image 2 de 2
    • Orient the laptop so the screen is open and facing you.
    • Grasp the top plate near the hinge and pull up.
    • This should expose a white ribbon cable.
  5. HP Pavilion dv7-1285dx Keyboard Replacement: étape 5, image 1 de 2 HP Pavilion dv7-1285dx Keyboard Replacement: étape 5, image 2 de 2
    • Locate the dark grey slide on the sides of the ribbon cable plug.
    • Using the plastic opening tool, push both sides of the dark gray slide towards the screen of the computer.
    • Unplug the ribbon cable and set the top plate aside.
  6. HP Pavilion dv7-1285dx Keyboard Replacement: étape 6, image 1 de 2 HP Pavilion dv7-1285dx Keyboard Replacement: étape 6, image 2 de 2
    • Locate the four Phillips M2.0x2 head screws at the top of the keyboard and remove them.
    • Gently lift the keyboard up from the screen side and pull the keyboard towards the screen.
  7. HP Pavilion dv7-1285dx Keyboard Replacement: étape 7, image 1 de 3 HP Pavilion dv7-1285dx Keyboard Replacement: étape 7, image 2 de 3 HP Pavilion dv7-1285dx Keyboard Replacement: étape 7, image 3 de 3
    • Locate the black ribbon cable attaching the keyboard to the computer.
    • Find the grey slides on the side of the ribbon cable plug.
    • Use the plastic opening tool to move the grey slides toward the screen.
    • Unplug the black ribbon cable.
    • Remove the keyboard.
2 autres ont terminé cette réparation.
Jesse Quisido
Membre depuis le 04/14/14
489 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 12-34, Maness Spring 2014 Membre de l'équipe Cal Poly, Team 12-34, Maness Spring 2014
CPSU-MANESS-S14S12G34
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 13
Total : 3,794
