Aller au contenu principal
HP Pavilion dv7-1285dx RAM Replacement
Ce dont vous avez besoin
  1. HP Pavilion dv7-1285dx RAM Replacement, Battery: étape 1, image 1 de 1
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx RAM Replacement, Back Plate: étape 2, image 1 de 1
    • Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
    • These screws do not completely detach from the device when unscrewed.
  3. HP Pavilion dv7-1285dx RAM Replacement: étape 3, image 1 de 2 HP Pavilion dv7-1285dx RAM Replacement: étape 3, image 2 de 2
    • Use the plastic opening tool to lift up the back plate and set it aside.
  4. HP Pavilion dv7-1285dx RAM Replacement, RAM: étape 4, image 1 de 1
    • Rotate the device 90 degrees to the left.
  5. HP Pavilion dv7-1285dx RAM Replacement: étape 5, image 1 de 3 HP Pavilion dv7-1285dx RAM Replacement: étape 5, image 2 de 3 HP Pavilion dv7-1285dx RAM Replacement: étape 5, image 3 de 3
    • Locate the grey clips on the side of the RAM and pull the grey clips away from the RAM using the plastic opening tool.
  6. HP Pavilion dv7-1285dx RAM Replacement: étape 6, image 1 de 3 HP Pavilion dv7-1285dx RAM Replacement: étape 6, image 2 de 3 HP Pavilion dv7-1285dx RAM Replacement: étape 6, image 3 de 3
    • Unplug the RAM.
    • Repeat step 6 to remove the second piece of RAM.
  7. HP Pavilion dv7-1285dx RAM Replacement: étape 7, image 1 de 2 HP Pavilion dv7-1285dx RAM Replacement: étape 7, image 2 de 2
    • These steps are important in the replacement of the RAM, they will assist in ensuring the device is not damaged.
    • Align the notch in the new RAM with the peg on the plug
    • Ensure the RAM is fully inserted into the plug at a 45 degree angle such that the notch of the RAM lines up with the peg on the plug
  8. HP Pavilion dv7-1285dx RAM Replacement: étape 8, image 1 de 2 HP Pavilion dv7-1285dx RAM Replacement: étape 8, image 2 de 2
    • Push down gently on the RAM until the grey clips click.
    • Repeat steps 7 and 8 to replace the second piece of RAM.
Jesse Quisido
Membre depuis le 04/14/14
489 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 12-34, Maness Spring 2014 Membre de l'équipe Cal Poly, Team 12-34, Maness Spring 2014
CPSU-MANESS-S14S12G34
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 1,135
