Aller au contenu principal
HP Pavilion dv7-1285dx Wifi Card Replacement
Ce dont vous avez besoin
  1. HP Pavilion dv7-1285dx Wifi Card Replacement, Battery: étape 1, image 1 de 1
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx Wifi Card Replacement, Back Plate: étape 2, image 1 de 1
    • Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
    • These screws do not completely detach from the device when unscrewed.
  3. HP Pavilion dv7-1285dx Wifi Card Replacement: étape 3, image 1 de 2 HP Pavilion dv7-1285dx Wifi Card Replacement: étape 3, image 2 de 2
    • Use the plastic opening tool to lift up the back plate and set it aside.
  4. HP Pavilion dv7-1285dx Wifi Card Replacement, Wifi Card: étape 4, image 1 de 1
    • Locate the wifi card to the right of the RAM.
  5. HP Pavilion dv7-1285dx Wifi Card Replacement: étape 5, image 1 de 1
    • Unplug antenna cables 1 and 2 from their leads.
    • Antenna cable 3 is not used.
  6. HP Pavilion dv7-1285dx Wifi Card Replacement: étape 6, image 1 de 1
    • Remove the two Phillips head screws located on the battery compartment side of the wifi card.
  7. HP Pavilion dv7-1285dx Wifi Card Replacement: étape 7, image 1 de 1
    • Gently lift the wifi card up to a 45 degree angle from the side with screws.
  8. HP Pavilion dv7-1285dx Wifi Card Replacement: étape 8, image 1 de 2 HP Pavilion dv7-1285dx Wifi Card Replacement: étape 8, image 2 de 2
    • Unplug the wifi card.
  9. HP Pavilion dv7-1285dx Wifi Card Replacement: étape 9, image 1 de 1
    • These next steps are for installing your replacement wifi card. These steps are very important to ensure that you do not damage your device.
    • Fully insert the replacement wifi card at a 45 degree angle, ensuring that the notch on the card lines up with the peg on the plug.
  10. HP Pavilion dv7-1285dx Wifi Card Replacement: étape 10, image 1 de 1
    • Gently push the wifi card down until the screws can be replaced.
  11. HP Pavilion dv7-1285dx Wifi Card Replacement: étape 11, image 1 de 1
    • Connect the antenna cable 1 with lead 1 and connect antenna cable 2 with lead 2.
    • Wire 1 needs to be connected to lead 1 and wire 2 needs to be connected to lead 2.
    • Wire 3 and lead 3 are not used.
2 autres ont terminé cette réparation.
Anmol Mathur
Membre depuis le 04/14/14
291 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 12-34, Maness Spring 2014 Membre de l'équipe Cal Poly, Team 12-34, Maness Spring 2014
CPSU-MANESS-S14S12G34
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 4
30 derniers jours : 18
Total : 2,158
