Aller au contenu principal
HP Pavilion dv7-4285dx Keyboard Replacement
Ce dont vous avez besoin
  1. HP Pavilion dv7-4285dx Keyboard  Replacement, Battery: étape 1, image 1 de 2 HP Pavilion dv7-4285dx Keyboard  Replacement, Battery: étape 1, image 2 de 2
    • Slide the battery release switch to the left. The battery pack will then subsequently release.
  2. HP Pavilion dv7-4285dx Keyboard  Replacement: étape 2, image 1 de 1
    • Remove the battery pack from the socket.
  3. HP Pavilion dv7-4285dx Keyboard  Replacement, Keyboard: étape 3, image 1 de 3 HP Pavilion dv7-4285dx Keyboard  Replacement, Keyboard: étape 3, image 2 de 3 HP Pavilion dv7-4285dx Keyboard  Replacement, Keyboard: étape 3, image 3 de 3
    • Unscrew the 5 black plate screws using a Ph#0 screwdriver.
    • During the removal process, the back plate will retain the 5 back plate screws.
    • Use a metal spudger to carefully remove back plate.
  4. HP Pavilion dv7-4285dx Keyboard  Replacement: étape 4, image 1 de 1
    • Unscrew the 7.2mm screws using a Ph#0 screwdriver.
  5. HP Pavilion dv7-4285dx Keyboard  Replacement: étape 5, image 1 de 2 HP Pavilion dv7-4285dx Keyboard  Replacement: étape 5, image 2 de 2
    • Push the keyboard release switch using the metal spudger.
  6. HP Pavilion dv7-4285dx Keyboard  Replacement: étape 6, image 1 de 2 HP Pavilion dv7-4285dx Keyboard  Replacement: étape 6, image 2 de 2
    • Lift up keyboard from its resting position.
  7. HP Pavilion dv7-4285dx Keyboard  Replacement: étape 7, image 1 de 3 HP Pavilion dv7-4285dx Keyboard  Replacement: étape 7, image 2 de 3 HP Pavilion dv7-4285dx Keyboard  Replacement: étape 7, image 3 de 3
    • Lift up black tab holding ribbon cable.
    • Remove ribbon cable from motherboard.
  8. HP Pavilion dv7-4285dx Keyboard  Replacement: étape 8, image 1 de 1
    • Remove keyboard.
Austin Sandel
Membre depuis le 11/05/18
363 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team S1-G2, Baechle Fall 2018 Membre de l'équipe IUPUI, Team S1-G2, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G2
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 12
Total : 432
