Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
A guide to replace the hard drive on the HP Pavilion dv7t-7000.
Pièces
Aucune pièce spécifiée.
  1. Turn the computer off and disconnect if from all power sources.
    • Turn the computer off and disconnect if from all power sources.
  2. Slide the battery release switch to the left.
    • Slide the battery release switch to the left.
  3. Hold the release switch all of the way to the left and your other hand to pull the battery out.
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. Unscrew the single Phillips #00 screw.
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. Manta Precision Bit Set
    112 embouts pour toute réparation.
    Upgrade Your Toolbox
  6. Remove service hatch by sliding away from the computer and lifting up. Remove service hatch by sliding away from the computer and lifting up.
    • Remove service hatch by sliding away from the computer and lifting up.
  7. Remove the two Phillips #00 screws holding in the hard drive.
    • Remove the two Phillips #00 screws holding in the hard drive.
  8. Grab the black tab on the hard drive and pull left and then upwards to remove. Grab the black tab on the hard drive and pull left and then upwards to remove.
    • Grab the black tab on the hard drive and pull left and then upwards to remove.
  9. Remove the four Phillips #00 screws holding the hard drive to its case.
    • Remove the four Phillips #00 screws holding the hard drive to its case.
  10. Slide the casing off of the hard drive. Slide the casing off of the hard drive.
    • Slide the casing off of the hard drive.
  11. Unplug the hard drive from the device.
    • Unplug the hard drive from the device.
Gavin Loera
Membre depuis le 21/02/2018
415 Réputation
3 tutoriels rédigés
Équipe
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 10
Total : 137
