Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
How to replace the speaker on a HP Pavilion dv7t-7000 laptop.
Pièces
Aucune pièce spécifiée.
  1. Turn the computer off and disconnect if from all power sources.
    • Turn the computer off and disconnect if from all power sources.
  2. Slide the battery release switch to the left.
    • Slide the battery release switch to the left.
  3. Hold the release switch all of the way to the left and your other hand to pull the battery out.
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. Unscrew the single Phillips #00 screw.
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. Manta Precision Bit Set
    112 embouts pour toute réparation.
    Upgrade Your Toolbox
  6. Remove service hatch by sliding away from the computer and lifting up. Remove service hatch by sliding away from the computer and lifting up.
    • Remove service hatch by sliding away from the computer and lifting up.
  7. Remove the single Phillips #00 screw. Flip the laptop over.
    • Remove the single Phillips #00 screw.
    • Flip the laptop over.
  8. Wedge a spudger in between the keyboard and palm rest bezel. Pry upward to release the keyboard clips. The keyboard is plugged into the motherboard, so be careful not to pull out while lifting keyboard.
    • Wedge a spudger in between the keyboard and palm rest bezel.
    • Pry upward to release the keyboard clips.
    • The keyboard is plugged into the motherboard, so be careful not to pull out while lifting keyboard.
  9. Use the flat end of a spudger to flip up the black tab on the ZIF connectors.
    • Use the flat end of a spudger to flip up the black tab on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors.
    • Remove the keyboard.
  10. Use Phillips #00 to unscrew the screw and take off the front panel. Use Phillips #00 to unscrew the screw and take off the front panel. Use Phillips #00 to unscrew the screw and take off the front panel.
    • Use Phillips #00 to unscrew the screw and take off the front panel.
  11. The speaker is located at the back side of the front panel. Unscrew two screws located at the speaker.
    • The speaker is located at the back side of the front panel.
    • Unscrew two screws located at the speaker.
  12. Pull out the speakers to remove.
    • Pull out the speakers to remove.
Nabin Bhatta
Membre depuis le 11/02/2018
258 Réputation
2 tutoriels rédigés
Équipe
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 19
Total : 216
