Aller au contenu principal
HP Pavilion dv9000 RAM Replacement
Ce dont vous avez besoin
  1. HP Pavilion dv9000 RAM Replacement, Battery: étape 1, image 1 de 1
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 RAM Replacement, Battery Removal: étape 2, image 1 de 2 HP Pavilion dv9000 RAM Replacement, Battery Removal: étape 2, image 2 de 2
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 RAM Replacement, RAM: étape 3, image 1 de 3 HP Pavilion dv9000 RAM Replacement, RAM: étape 3, image 2 de 3 HP Pavilion dv9000 RAM Replacement, RAM: étape 3, image 3 de 3
    • Locate the middle plastic cover on the bottom of the laptop.
    • Unscrew the two 5mm screws using a Phillips #1 screwdriver. The screws should remain in the plastic cover.
    • Lift and remove the plastic cover.
  4. HP Pavilion dv9000 RAM Replacement: étape 4, image 1 de 3 HP Pavilion dv9000 RAM Replacement: étape 4, image 2 de 3 HP Pavilion dv9000 RAM Replacement: étape 4, image 3 de 3
    • Locate the RAM card and the metal tabs on either side of it.
    • Press both tabs away from the RAM card to release it. The card should flip up towards you.
    • Carefully lift the RAM card out.
Erik Hoffnagle
Membre depuis le 04/11/13
750 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 10-32, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 10-32, Maness Winter 2014
CPSU-MANESS-W14S10G32
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 18
Total : 3,536
