Aller au contenu principal
HP Pavilion dv9000 Wireless Card Replacement
Ce dont vous avez besoin
  1. HP Pavilion dv9000 Wireless Card Replacement, Battery: étape 1, image 1 de 1
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 Wireless Card Replacement, Battery Removal: étape 2, image 1 de 2 HP Pavilion dv9000 Wireless Card Replacement, Battery Removal: étape 2, image 2 de 2
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: étape 3, image 1 de 3 HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: étape 3, image 2 de 3 HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: étape 3, image 3 de 3
    • Locate the panel that lies in the front center of the laptops underside.
    • Using a Phillips #1 screwdriver, remove the two 5mm screws on the forward end of the cover.
    • Lift off the cover to expose the Wi-Fi card underneath.
  4. HP Pavilion dv9000 Wireless Card Replacement: étape 4, image 1 de 3 HP Pavilion dv9000 Wireless Card Replacement: étape 4, image 2 de 3 HP Pavilion dv9000 Wireless Card Replacement: étape 4, image 3 de 3
    • Locate the Wi-Fi card inside of the computer.
    • With a Phillips #1 screwdriver, remove the two 11mm screws on either side of the wires attached to the top of the Wi-Fi card.
    • Lift the card from its resting location. Be careful, the card and attached wires are fragile.
  5. HP Pavilion dv9000 Wireless Card Replacement: étape 5, image 1 de 2 HP Pavilion dv9000 Wireless Card Replacement: étape 5, image 2 de 2
    • Carefully pop the wires off of the Wi-Fi card. They should easily come off with a light tug.
    • As you take each wire off, keep track of the numbered labels. These numbers correspond with contact points on the card.
2 autres ont terminé cette réparation.
Erik Hoffnagle
Membre depuis le 04/11/13
768 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 10-32, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 10-32, Maness Winter 2014
CPSU-MANESS-W14S10G32
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 13
Total : 3,960
