Aller au contenu principal
HP Pavilion g4-1117dx Motherboard Replacement
Ce dont vous avez besoin
  1. HP Pavilion g4-1117dx Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Slide pill shaped tab to the other side of the channel.
    • Remove battery while keeping the tab to the side.
  2. HP Pavilion g4-1117dx Motherboard Replacement, L-Shaped Back Panel: étape 3, image 1 de 1
    • Unscrew the two screws JIS #0 located on opposites sides of the panel.
    • Screws are attached to the panel and will not fully come out.
  3. HP Pavilion g4-1117dx Motherboard Replacement: étape 4, image 1 de 1
    • Carefully pry off the L-shaped panel.
  4. HP Pavilion g4-1117dx Motherboard Replacement, Hard Drive: étape 5, image 1 de 1
    • Pull out and unplug the tab on the right hand side.
  5. HP Pavilion g4-1117dx Motherboard Replacement, Larger Back Panel: étape 6, image 1 de 1
    • Unscrew all nine 6.0mm JIS #0 screws located on the border of the back panel.
  6. HP Pavilion g4-1117dx Motherboard Replacement: étape 7, image 1 de 1
    • Remove 3 screws located where the battery previously was.
  7. HP Pavilion g4-1117dx Motherboard Replacement: étape 8, image 1 de 2 HP Pavilion g4-1117dx Motherboard Replacement: étape 8, image 2 de 2
    • Remove 6 screws located under the spot where the smaller L-shaped panel was located.
  8. HP Pavilion g4-1117dx Motherboard Replacement: étape 9, image 1 de 1
    • Slowly pry off the keyboard from the back panel.
    • Between the back panel and the keyboard there are two ribbon wires.
    • Remove slowly to not break the back panel. If it does not come off easily, check to see if all screws are removed.
  9. HP Pavilion g4-1117dx Motherboard Replacement: étape 10, image 1 de 1
    • Unplug wires connecting back panel to keyboard.
  10. HP Pavilion g4-1117dx Motherboard Replacement, Motherboard: étape 11, image 1 de 2 HP Pavilion g4-1117dx Motherboard Replacement, Motherboard: étape 11, image 2 de 2
    • In lower left hand corner, pull on black tab to unplug the disc drive.
  11. HP Pavilion g4-1117dx Motherboard Replacement: étape 12, image 1 de 2 HP Pavilion g4-1117dx Motherboard Replacement: étape 12, image 2 de 2
    • In upper left hand corner, unplug the large black electrical tape covered laptop plug.
Robert Hamilton
Membre depuis le 03/01/18
1 165 Réputation
10 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G7, Simcock Spring 2018 Membre de l'équipe UMass Dartmouth, Team S2-G7, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G7
4 membres
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 17
Total : 1,134
