Aller au contenu principal
HP Pavilion g6-1b79dx RAM Replacement
Ce dont vous avez besoin
  1. HP Pavilion g6-1b79dx RAM Replacement, Battery: étape 1, image 1 de 1
    • Flip the computer so the bottom is facing up with the battery away from you.
    • Turn off the computer and disconnect the charger.
  2. HP Pavilion g6-1b79dx RAM Replacement: étape 2, image 1 de 2 HP Pavilion g6-1b79dx RAM Replacement: étape 2, image 2 de 2
    • Slide the battery switch to the left until the battery unlatches from the base of the laptop.
  3. HP Pavilion g6-1b79dx RAM Replacement: étape 3, image 1 de 2 HP Pavilion g6-1b79dx RAM Replacement: étape 3, image 2 de 2
    • Lift the battery from its compartment away from the laptop.
  4. HP Pavilion g6-1b79dx RAM Replacement, Bottom Panel: étape 4, image 1 de 1
    • Loosen the two 5.7 mm screws on the bottom panel using a PH00 screwdriver.
    • The screws do not come out of the panel due to small washers. Do not try to remove the screws completely.
  5. HP Pavilion g6-1b79dx RAM Replacement: étape 5, image 1 de 1
    • Use the metal spudger all around the panel to pop it up from the base.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Using your finger is acceptable but not entirely recommended. Be gentle if you choose to use your hands.
  6. HP Pavilion g6-1b79dx RAM Replacement: étape 6, image 1 de 3 HP Pavilion g6-1b79dx RAM Replacement: étape 6, image 2 de 3 HP Pavilion g6-1b79dx RAM Replacement: étape 6, image 3 de 3
    • With your hands, lift the panel completely off the base of the laptop.
  7. HP Pavilion g6-1b79dx RAM Replacement, RAM: étape 7, image 1 de 3 HP Pavilion g6-1b79dx RAM Replacement, RAM: étape 7, image 2 de 3 HP Pavilion g6-1b79dx RAM Replacement, RAM: étape 7, image 3 de 3
    • Slide the two latches away from the RAM to unhook it.
  8. HP Pavilion g6-1b79dx RAM Replacement: étape 8, image 1 de 3 HP Pavilion g6-1b79dx RAM Replacement: étape 8, image 2 de 3 HP Pavilion g6-1b79dx RAM Replacement: étape 8, image 3 de 3
    • Gently slide the RAM out from the laptop.
Rachel Gallegos
Membre depuis le 09/22/15
873 Réputation
5 tutoriels rédigés
Équipe
Baylor, Team 10-12, Williams Fall 2015 Membre de l'équipe Baylor, Team 10-12, Williams Fall 2015
BU-WILLIAMS-F15S10G12
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 25
Total : 922
