Aller au contenu principal
HP Pavilion g6-1b79dx Speaker Replacement
Ce dont vous avez besoin
  1. HP Pavilion g6-1b79dx Speaker Replacement, Battery: étape 1, image 1 de 1
    • Flip the computer so the bottom is facing up with the battery away from you.
    • Turn off the computer and disconnect the charger.
  2. HP Pavilion g6-1b79dx Speaker Replacement: étape 2, image 1 de 2 HP Pavilion g6-1b79dx Speaker Replacement: étape 2, image 2 de 2
    • Slide the battery switch to the left until the battery unlatches from the base of the laptop.
  3. HP Pavilion g6-1b79dx Speaker Replacement: étape 3, image 1 de 2 HP Pavilion g6-1b79dx Speaker Replacement: étape 3, image 2 de 2
    • Lift the battery from its compartment away from the laptop.
  4. HP Pavilion g6-1b79dx Speaker Replacement, Bottom Panel: étape 4, image 1 de 1
    • Loosen the two 5.7 mm screws on the bottom panel using a PH00 screwdriver.
    • The screws do not come out of the panel due to small washers. Do not try to remove the screws completely.
  5. HP Pavilion g6-1b79dx Speaker Replacement: étape 5, image 1 de 1
    • Use the metal spudger all around the panel to pop it up from the base.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Using your finger is acceptable but not entirely recommended. Be gentle if you choose to use your hands.
  6. HP Pavilion g6-1b79dx Speaker Replacement: étape 6, image 1 de 3 HP Pavilion g6-1b79dx Speaker Replacement: étape 6, image 2 de 3 HP Pavilion g6-1b79dx Speaker Replacement: étape 6, image 3 de 3
    • With your hands, lift the panel completely off the base of the laptop.
  7. HP Pavilion g6-1b79dx Speaker Replacement, RAM: étape 7, image 1 de 3 HP Pavilion g6-1b79dx Speaker Replacement, RAM: étape 7, image 2 de 3 HP Pavilion g6-1b79dx Speaker Replacement, RAM: étape 7, image 3 de 3
    • Slide the two latches away from the RAM to unhook it.
  8. HP Pavilion g6-1b79dx Speaker Replacement: étape 8, image 1 de 3 HP Pavilion g6-1b79dx Speaker Replacement: étape 8, image 2 de 3 HP Pavilion g6-1b79dx Speaker Replacement: étape 8, image 3 de 3
    • Gently slide the RAM out from the laptop.
  9. HP Pavilion g6-1b79dx Speaker Replacement, Hard Drive: étape 9, image 1 de 2 HP Pavilion g6-1b79dx Speaker Replacement, Hard Drive: étape 9, image 2 de 2
    • Use the PH 00 screwdriver to unscrew the 2.5 mm screw to the right of the hard drive.
  10. HP Pavilion g6-1b79dx Speaker Replacement: étape 10, image 1 de 3 HP Pavilion g6-1b79dx Speaker Replacement: étape 10, image 2 de 3 HP Pavilion g6-1b79dx Speaker Replacement: étape 10, image 3 de 3
    • Pull the triangular blue tab to diconnect and remove the hard drive. You can see the word 'Pull' on the cover.
  11. HP Pavilion g6-1b79dx Speaker Replacement, Wireless Card: étape 11, image 1 de 3 HP Pavilion g6-1b79dx Speaker Replacement, Wireless Card: étape 11, image 2 de 3 HP Pavilion g6-1b79dx Speaker Replacement, Wireless Card: étape 11, image 3 de 3
    • Unlatch the two antenna cable connectors from the wireless card.
  12. HP Pavilion g6-1b79dx Speaker Replacement: étape 12, image 1 de 1
    • Remove the two 2.5 mm screws in the wireless card with a PH00 screwdriver.
    • You may have to gently bend the cables away from the wireless card to remove the screws
  13. HP Pavilion g6-1b79dx Speaker Replacement: étape 13, image 1 de 3 HP Pavilion g6-1b79dx Speaker Replacement: étape 13, image 2 de 3 HP Pavilion g6-1b79dx Speaker Replacement: étape 13, image 3 de 3
    • Gently disconnect the wireless card from the laptop.
  14. HP Pavilion g6-1b79dx Speaker Replacement, CD Drive: étape 14, image 1 de 2 HP Pavilion g6-1b79dx Speaker Replacement, CD Drive: étape 14, image 2 de 2
    • Using the PH 00 screwdriver, remove the screw left of the CD drive.
  15. HP Pavilion g6-1b79dx Speaker Replacement: étape 15, image 1 de 3 HP Pavilion g6-1b79dx Speaker Replacement: étape 15, image 2 de 3 HP Pavilion g6-1b79dx Speaker Replacement: étape 15, image 3 de 3
    • Slide the CD drive out from the exterior of the laptop.
  16. HP Pavilion g6-1b79dx Speaker Replacement, Keyboard: étape 16, image 1 de 1
    • Using a PH 00 screwdriver, remove the screw located next to the wireless card.
    • You can remove the wireless card for this process but it is not necessary.
    • This screw has a small keyboard icon next to it.
  17. HP Pavilion g6-1b79dx Speaker Replacement: étape 17, image 1 de 1
    • Flip the laptop over and open it.
    • The components beneath your computer may be loose and fall out when you flip the laptop. Be careful when turning it over.
  18. HP Pavilion g6-1b79dx Speaker Replacement: étape 18, image 1 de 3 HP Pavilion g6-1b79dx Speaker Replacement: étape 18, image 2 de 3 HP Pavilion g6-1b79dx Speaker Replacement: étape 18, image 3 de 3
    • Insert a plastic spudger or similar pry tool, beneath the keyboard, near the "insert" key, and pop the keyboard up from the laptop.
    • Starting at the opening you just created, run your fingers around the outside of the keyboard separating it from the rest of the computer.
    • Only lift the keyboard up a few inches because it is attached to the laptop by a ribbon cable.
  19. HP Pavilion g6-1b79dx Speaker Replacement: étape 19, image 1 de 3 HP Pavilion g6-1b79dx Speaker Replacement: étape 19, image 2 de 3 HP Pavilion g6-1b79dx Speaker Replacement: étape 19, image 3 de 3
    • Slightly angle the keyboard back so the ribbon connector underneath it is visible.
    • Remove the ribbon cable by using your fingers to pull up and away from the connector.
  20. HP Pavilion g6-1b79dx Speaker Replacement: étape 20, image 1 de 1
    • With the ribbon cable detached, you can now completely remove the keyboard.
  21. HP Pavilion g6-1b79dx Speaker Replacement, Speaker: étape 21, image 1 de 3 HP Pavilion g6-1b79dx Speaker Replacement, Speaker: étape 21, image 2 de 3 HP Pavilion g6-1b79dx Speaker Replacement, Speaker: étape 21, image 3 de 3
    • With the laptop bottom facing up, locate the rubber plug on the right side of the computer.
    • Use a metal splunger to remove the plug.
  22. HP Pavilion g6-1b79dx Speaker Replacement: étape 22, image 1 de 1
    • Remove the ten 6.7 mm screws using a PH00 screwdriver.
    • Remove the five 3.4 mm screws using a PH00 screwdriver.
  23. HP Pavilion g6-1b79dx Speaker Replacement: étape 23, image 1 de 1
    • Flip the computer over and open it.
    • Detach the two purple ribbons from the ribbon connectors.
    • Unscrew the six 4.6 mm screws using the PH00 screwdriver.
  24. HP Pavilion g6-1b79dx Speaker Replacement: étape 24, image 1 de 3 HP Pavilion g6-1b79dx Speaker Replacement: étape 24, image 2 de 3 HP Pavilion g6-1b79dx Speaker Replacement: étape 24, image 3 de 3
    • Use the plastic opening tool to pry out the front panel around the entire computer.
  25. HP Pavilion g6-1b79dx Speaker Replacement: étape 25, image 1 de 3 HP Pavilion g6-1b79dx Speaker Replacement: étape 25, image 2 de 3 HP Pavilion g6-1b79dx Speaker Replacement: étape 25, image 3 de 3
    • Gently lift the front panel away from the computer.
  26. HP Pavilion g6-1b79dx Speaker Replacement: étape 26, image 1 de 3 HP Pavilion g6-1b79dx Speaker Replacement: étape 26, image 2 de 3 HP Pavilion g6-1b79dx Speaker Replacement: étape 26, image 3 de 3
    • Locate the red and black speaker cables connecting the speakers and detach them from the two holders.
  27. HP Pavilion g6-1b79dx Speaker Replacement: étape 27, image 1 de 3 HP Pavilion g6-1b79dx Speaker Replacement: étape 27, image 2 de 3 HP Pavilion g6-1b79dx Speaker Replacement: étape 27, image 3 de 3
    • Pull the speaker cables out of their connectors.
  28. HP Pavilion g6-1b79dx Speaker Replacement: étape 28, image 1 de 2 HP Pavilion g6-1b79dx Speaker Replacement: étape 28, image 2 de 2
    • Slide the left speaker out from under the blue motherboard.
  29. HP Pavilion g6-1b79dx Speaker Replacement: étape 29, image 1 de 3 HP Pavilion g6-1b79dx Speaker Replacement: étape 29, image 2 de 3 HP Pavilion g6-1b79dx Speaker Replacement: étape 29, image 3 de 3
    • Lift the right speaker directly up and remove it from the computer.
10 autres ont terminé cette réparation.
Rachel Gallegos
Membre depuis le 09/22/15
873 Réputation
5 tutoriels rédigés
Équipe
Baylor, Team 10-12, Williams Fall 2015 Membre de l'équipe Baylor, Team 10-12, Williams Fall 2015
BU-WILLIAMS-F15S10G12
3 membres
8 tutoriels rédigés
2 commentaires
I Love the practical very much
Mamadoumolo Jalloh - Réponse
HP Pavilion g6 price
YASIR KHAN OFFICIAL - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 30
Total : 6,667
