Aller au contenu principal
HP Pavilion g6-2228tx Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion g6-2228tx Hard Drive Replacement, Battery: étape 1, image 1 de 2 HP Pavilion g6-2228tx Hard Drive Replacement, Battery: étape 1, image 2 de 2
    • Push the battery latch to the left to release the battery.
    • Remove the battery from the device.
  2. HP Pavilion g6-2228tx Hard Drive Replacement, Hard Drive: étape 2, image 1 de 2 HP Pavilion g6-2228tx Hard Drive Replacement, Hard Drive: étape 2, image 2 de 2
    • Use a Phillips #0 screw driver to loosen the screw. The screw will not detach from the cover.
  3. HP Pavilion g6-2228tx Hard Drive Replacement: étape 3, image 1 de 3 HP Pavilion g6-2228tx Hard Drive Replacement: étape 3, image 2 de 3 HP Pavilion g6-2228tx Hard Drive Replacement: étape 3, image 3 de 3
    • Place your hand on the cover and slide the cover down.
    • Use your hand to lift the cover from the bottom right and slide the cover to the right to remove the cover.
  4. HP Pavilion g6-2228tx Hard Drive Replacement: étape 4, image 1 de 2 HP Pavilion g6-2228tx Hard Drive Replacement: étape 4, image 2 de 2
    • Place one finger on the right side of the hard drive.
    • Push the hard drive to the left and lift the hard drive up to remove it from the device.
  5. HP Pavilion g6-2228tx Hard Drive Replacement: étape 5, image 1 de 2 HP Pavilion g6-2228tx Hard Drive Replacement: étape 5, image 2 de 2
    • Disconnect the connecting part by pulling the part to the right.
    • Remove the hard drive from the device.
Hai Lin
Membre depuis le 10/19/18
446 Réputation
4 tutoriels rédigés
Équipe
UC Davis, Team S4-G6, Lore Fall 2018 Membre de l'équipe UC Davis, Team S4-G6, Lore Fall 2018
UCD-LORE-F18S4G6
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 17
Total : 930
