Aller au contenu principal
HP Pavilion g7-1150us Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion g7-1150us Hard Drive Replacement, Battery: étape 1, image 1 de 2 HP Pavilion g7-1150us Hard Drive Replacement, Battery: étape 1, image 2 de 2
    • Slide the battery removal switch towards the center of the laptop until the battery pops out.
  2. HP Pavilion g7-1150us Hard Drive Replacement: étape 2, image 1 de 1
    • Remove the battery from the computer.
  3. HP Pavilion g7-1150us Hard Drive Replacement, Surface Panel: étape 3, image 1 de 1
    • Unscrew the two 4mm Phillips #0 screws found in the surface panel.
  4. HP Pavilion g7-1150us Hard Drive Replacement: étape 4, image 1 de 2 HP Pavilion g7-1150us Hard Drive Replacement: étape 4, image 2 de 2
    • Using the spudger, pry the surface panel off starting from the side where the battery was located.
    • Pry the remainder of the panel off by sliding the spudger underneath the panel and gently lifting.
    • Aim for the corners of the panel while using the spudger to methodically remove it without damaging it.
  5. HP Pavilion g7-1150us Hard Drive Replacement: étape 5, image 1 de 1
    • Lift the pried surface panel off of the computer.
  6. HP Pavilion g7-1150us Hard Drive Replacement, Hard Drive: étape 6, image 1 de 1
    • Grab the hard drive gently on either side. The left side is where the hard drive is connected to the laptop.
    • The hard drive was missing from our device.
  7. HP Pavilion g7-1150us Hard Drive Replacement: étape 7, image 1 de 1
    • Gently pull the hard drive to the right away from the connector. When fully disconnected you have safely removed the hard drive!
2 autres ont terminé cette réparation.
Gabriel Lurz
Membre depuis le 03/20/19
127 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S6-G3, Peak Spring 2019 Membre de l'équipe UMass Dartmouth, Team S6-G3, Peak Spring 2019
UMASSD-PEAK-S19S6G3
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 17
Total : 807
