Introduction
This guide will provide a step by step instruction on how to replace the keyboard on your HP Pavilion g7-1365dx. Use this guide if keyboard has already been diagnosed that it is damage and there is no other solution other than replacing the the keyboard.
Ce dont vous avez besoin
Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
Push the switch above the battery towards the center of the laptop .
Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
Use the opening tool around the edges of the service door to loosen it and remove it.
Remove the 4.7 mm screw that secures the keyboard to the computer using the Philips 00 screwdriver.
