Aller au contenu principal
HP Pavilion g7-1365dx RTC Battery Replacement
Ce dont vous avez besoin
  1. HP Pavilion g7-1365dx RTC Battery Replacement, Battery: étape 1, image 1 de 1
    • To prevent injury, make sure the laptop is powered off before removing the battery.
    • Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
    • Push the switch above the battery towards the center of the laptop .
  2. HP Pavilion g7-1365dx RTC Battery Replacement: étape 2, image 1 de 1
    • While pushing the switch, lift the battery by the side closest to the switch up and away from the laptop.
  3. HP Pavilion g7-1365dx RTC Battery Replacement, Service Door: étape 3, image 1 de 2 HP Pavilion g7-1365dx RTC Battery Replacement, Service Door: étape 3, image 2 de 2
    • Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
    • Use the opening tool around the edges of the service door to loosen it and remove it.
  4. HP Pavilion g7-1365dx RTC Battery Replacement, RTC Battery: étape 4, image 1 de 2 HP Pavilion g7-1365dx RTC Battery Replacement, RTC Battery: étape 4, image 2 de 2
    • Disconnect the RTC battery power cable from the system board.
    • Remove the RTC battery from the system board. (The RTC battery is attached to the system board with double-sided tape.)
    • Slide the RTC battery out from under the surface of the base enclosure.
Derrick Manu
Membre depuis le 03/18/19
245 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G1, Simcock Spring 2019 Membre de l'équipe UMass Dartmouth, Team S1-G1, Simcock Spring 2019
UMASSD-SIMCOCK-S19S1G1
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 20
Total : 1,542
