Introduction
In this guide, you will learn how to replace the keyboard of your HP Pavilion g7-1368dx. this process takes roughly 25 minutes. The tools that you will need to preform this replacement are a Philips #1 Screwdriver, and the plastic iFixit opening tool.
Ce dont vous avez besoin
Turn the device over so that the lower case is facing up.
Slide the battery release latch. The battery will pop up.
Loosen the two Phillips #1 screws that connect the service panel to the device.
Slide the service panel down and pull it up to remove.
