Introduction
There are a few reasons you may want to replace your RAM. You don’t have enough RAM to run a particular program or your device is slow. Whatever the reason, this guide will show you how to replace the RAM.
This device supports up to 8 GB of system RAM. This guide is written for the maximum amount of RAM for your device. The RAM that is sold on the market that is compatible with this device comes in either 2 GB or 4 GB per RAM modules. You can’t use both 2 GB and 4GB of RAM together. If you plan to upgrade the RAM on the system, both RAM modules must be the same size.
Ce dont vous avez besoin
Place your finger on the battery lock slider, press toward the center of the laptop to unlock the battery.
