Aller au contenu principal
HP Pavilion g7-2023cl Service Door Replacement
Ce dont vous avez besoin
  1. HP Pavilion g7-2023cl Service Door Replacement, Battery: étape 1, image 1 de 1
    • Shut off your device and disconnect the power cord. Disconnect any external devices connected to the device.
    • Place your finger on the battery lock slider, press toward the center of the laptop to unlock the battery.
    • The lock will make a click sound letting you know that the battery is unlocked.
  2. HP Pavilion g7-2023cl Service Door Replacement: étape 2, image 1 de 3 HP Pavilion g7-2023cl Service Door Replacement: étape 2, image 2 de 3 HP Pavilion g7-2023cl Service Door Replacement: étape 2, image 3 de 3
    • Use your thumb to pry up the edge of the battery and lift it out of the device.
    • When replacing the battery, align the notch on the battery with the battery lock on the device. Gently press down on the battery until you hear the lock click, which signals that the battery is secure.
  3. HP Pavilion g7-2023cl Service Door Replacement, Service Door: étape 3, image 1 de 2 HP Pavilion g7-2023cl Service Door Replacement, Service Door: étape 3, image 2 de 2
    • Using a Phillips #0 screwdriver, loosen the service door screw.
    • This is a captive screw that will remain attached to the service door.
  4. HP Pavilion g7-2023cl Service Door Replacement: étape 4, image 1 de 2 HP Pavilion g7-2023cl Service Door Replacement: étape 4, image 2 de 2
    • Lift the service door up and away from the device.
Thomas Maloney
Membre depuis le 03/21/19
1 060 Réputation
9 tutoriels rédigés
Équipe
UMass Dartmouth, Team S8-G4, Bailey Spring 2019 Membre de l'équipe UMass Dartmouth, Team S8-G4, Bailey Spring 2019
UMASSD-BAILEY-S19S8G4
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 312
