Aller au contenu principal
HP Pavilion g7-2275dx Battery Replacement
Ce dont vous avez besoin
  1. HP Pavilion g7-2275dx Battery Replacement, Battery: étape 1, image 1 de 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
  2. HP Pavilion g7-2275dx Battery Replacement: étape 2, image 1 de 1
    • The battery is held in by a latch in the front and tabs in the back.
    • Slide the lock switch left, towards the center of the computer.
    • Lift up the battery, rotating it up and away from you, then pull it out.
    • To put the battery back in, line it up with the battery bay and the holes for the tabs. Then let the battery rotate towards you and press down until the latch engages and you hear a click.
2 autres ont terminé cette réparation.
John Sutton
Membre depuis le 04/24/14
1 566 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 11-51, Amido Spring 2014 Membre de l'équipe Cal Poly, Team 11-51, Amido Spring 2014
CPSU-AMIDO-S14S11G51
4 membres
21 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 15
Total : 1,358
