Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HP Pavilion p6 Wireless Card Replacement
Ce dont vous avez besoin
  1. HP Pavilion p6 Wireless Card Replacement, Side Panel Removal: étape 1, image 1 de 3 HP Pavilion p6 Wireless Card Replacement, Side Panel Removal: étape 1, image 2 de 3 HP Pavilion p6 Wireless Card Replacement, Side Panel Removal: étape 1, image 3 de 3
    • Before you start make sure that all of the leads have been disconnected from the computer.
    • It is strongly recomended to wait at least 15 minutes after turning it off to allow the computer and internal components to cool down.
    • It is recomended to lay the computer down with the pull tab at the top to allow it to be easily opened.
    • It is also worth mentioning at this point that for complete safety when working inside the computer that wearing an anti-static band and touching a grounded metal object before starting is good practice.
    Demander à FixBot
    Ajouter un commentaire
  2. HP Pavilion p6 Wireless Card Replacement: étape 2, image 1 de 3 HP Pavilion p6 Wireless Card Replacement: étape 2, image 2 de 3 HP Pavilion p6 Wireless Card Replacement: étape 2, image 3 de 3
    • In order to remove the side panel a single screw needs to first be removed.
    • The side panel can then be pulled towards the back of the computer using the pull tab provided.
    • The panel then needs to be rotated as showen in order to remove it from the computer.
    Demander à FixBot
  3. HP Pavilion p6 Wireless Card Replacement, Wireless Card: étape 3, image 1 de 3 HP Pavilion p6 Wireless Card Replacement, Wireless Card: étape 3, image 2 de 3 HP Pavilion p6 Wireless Card Replacement, Wireless Card: étape 3, image 3 de 3
    • First locate the wireless card, it should look like this.
    • Next using a spudger or equivalent carefully pry the antenna cable off the wireless card, it should now look like the second picture.
    • A single screw then needs to be removed in order to free the card.
    Demander à FixBot
  4. HP Pavilion p6 Wireless Card Replacement: étape 4, image 1 de 2 HP Pavilion p6 Wireless Card Replacement: étape 4, image 2 de 2
    • The card can then just be easily removed by pulling it out and up.
    • The wireless card should then be kept in a safe place and care taken not to lose the small screw that goes with it.
    Demander à FixBot
8 autres ont terminé cette réparation.
Oli
Membre depuis le 01/03/14
1 577 Réputation
4 tutoriels rédigés
2 commentaires de tutoriel
Thx this helped a lot with my pc
Nathan Moore - Réponse Partager
Also will the card still work without the antenna cable?
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 46
Total : 3,553
