Aller au contenu principal
HP Pavilion tx2500 Screen Rotator Replacement
Ce dont vous avez besoin
  1. HP Pavilion tx2500 Screen Rotator Replacement, Screen Rotator: étape 1, image 1 de 1
    • Completely turn off and unplug device. Lay the device bottom side up on a soft surface.
  2. HP Pavilion tx2500 Screen Rotator Replacement: étape 2, image 1 de 2 HP Pavilion tx2500 Screen Rotator Replacement: étape 2, image 2 de 2
    • Squeeze the latches on the battery until you hear a click. Slide out the battery.
  3. HP Pavilion tx2500 Screen Rotator Replacement: étape 3, image 1 de 1
    • Using the Phillips #0 screwdriver, remove the 4.5 mm screw from the WLAN model screen.
    • Once unscrewed, lift the right side of the WLAN module compartment cover and swing it to the left.
  4. HP Pavilion tx2500 Screen Rotator Replacement: étape 4, image 1 de 1
    • Using the plastic opening tool, disconnect the WLAN antenna cables from the WLAN module.
  5. HP Pavilion tx2500 Screen Rotator Replacement: étape 5, image 1 de 1
    • Using the Phillips #0 screwdriver, unscrew the 4.5 mm screw from the middle section in the battery compartment.
  6. HP Pavilion tx2500 Screen Rotator Replacement: étape 6, image 1 de 1
    • Use the plastic opening tool to disconnect the wires in the upper corners.
  7. HP Pavilion tx2500 Screen Rotator Replacement: étape 7, image 1 de 1
    • Flip the laptop front side up and then use your fingers to lift up the keyboard.
  8. HP Pavilion tx2500 Screen Rotator Replacement: étape 8, image 1 de 1
    • Lift up the black latch that connects the film strip to the base of the computer.
    • Use the plastic opening tool to disconnect the film strip from the base of the computer.
  9. HP Pavilion tx2500 Screen Rotator Replacement: étape 9, image 1 de 2 HP Pavilion tx2500 Screen Rotator Replacement: étape 9, image 2 de 2
    • Rotate the screen 90 degrees and remove the base under the screen.
  10. HP Pavilion tx2500 Screen Rotator Replacement: étape 10, image 1 de 1
    • Rotate the screen back towards you.
    • Lift up the convertible hinge to unclip it from the base of the computer.
  11. HP Pavilion tx2500 Screen Rotator Replacement: étape 11, image 1 de 2 HP Pavilion tx2500 Screen Rotator Replacement: étape 11, image 2 de 2
    • Using the Phillips #0 screwdriver, remove both of the 5.0 mm screws on the base of the rotator.
  12. HP Pavilion tx2500 Screen Rotator Replacement: étape 12, image 1 de 1
    • Gently lift up and remove the screen.
Sarah Naiser
Membre depuis le 10/13/15
324 Réputation
2 tutoriels rédigés
Équipe
Sam Houston State, Team 1-4, Blackburne Fall 2015 Membre de l'équipe Sam Houston State, Team 1-4, Blackburne Fall 2015
SHSU-BLACKBURNE-F15S1G4
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 650
