Aller au contenu principal
HP Pavilion x2 10-n113dx Mainboard Replacement
Ce dont vous avez besoin
  1. HP Pavilion x2 10-n113dx  Mainboard Replacement, Battery: étape 1, image 1 de 3 HP Pavilion x2 10-n113dx  Mainboard Replacement, Battery: étape 1, image 2 de 3 HP Pavilion x2 10-n113dx  Mainboard Replacement, Battery: étape 1, image 3 de 3
    • Before starting, please turn off your laptop.
    • Using the blue plastic opening tool or a flat bladed tool, carefully slide the blade in between the display panel and gently slide to prop open the assembly.
  2. HP Pavilion x2 10-n113dx  Mainboard Replacement: étape 2, image 1 de 2 HP Pavilion x2 10-n113dx  Mainboard Replacement: étape 2, image 2 de 2
    • Gently lift and remove the display panel from the assembly.
    • Remove the translucent yellow tape that covers the battery connector on the mainboard.
    • The tape will be in the way for a future step.
  3. HP Pavilion x2 10-n113dx  Mainboard Replacement: étape 3, image 1 de 3 HP Pavilion x2 10-n113dx  Mainboard Replacement: étape 3, image 2 de 3 HP Pavilion x2 10-n113dx  Mainboard Replacement: étape 3, image 3 de 3
    • Flip up the small white colored locking flap using the tip of a spudger or your fingernail. Then the ribbon cable can be removed easily without much effort.
    • Carefully disconnect the white ribbon cable from the mainboard.
  4. HP Pavilion x2 10-n113dx  Mainboard Replacement: étape 4, image 1 de 3 HP Pavilion x2 10-n113dx  Mainboard Replacement: étape 4, image 2 de 3 HP Pavilion x2 10-n113dx  Mainboard Replacement: étape 4, image 3 de 3
    • Carefully disconnect the battery cable from its connector on the mainboard.
  5. HP Pavilion x2 10-n113dx  Mainboard Replacement: étape 5, image 1 de 3 HP Pavilion x2 10-n113dx  Mainboard Replacement: étape 5, image 2 de 3 HP Pavilion x2 10-n113dx  Mainboard Replacement: étape 5, image 3 de 3
    • Using the Phillips #0 screwdriver, carefully remove the 4 corner screws that hold the battery to the display panel.
    • 3 screws are 3.12 mm head, 2.40 mm length, and 1 screw is 5.85mm head, 2.5mm length.
    • Remove the battery from the device.
  6. HP Pavilion x2 10-n113dx  Mainboard Replacement, Mainboard: étape 6, image 1 de 3 HP Pavilion x2 10-n113dx  Mainboard Replacement, Mainboard: étape 6, image 2 de 3 HP Pavilion x2 10-n113dx  Mainboard Replacement, Mainboard: étape 6, image 3 de 3
    • To unscrew the mainboard use the Phillips #0 Screwdriver to remove two types of screws. Three 4.15mm head, 2.35mm in length screws and three 3.32mm head, 3.99mm in length screws
  7. HP Pavilion x2 10-n113dx  Mainboard Replacement: étape 7, image 1 de 3 HP Pavilion x2 10-n113dx  Mainboard Replacement: étape 7, image 2 de 3 HP Pavilion x2 10-n113dx  Mainboard Replacement: étape 7, image 3 de 3
    • Remove mainboard.
4 autres ont terminé cette réparation.
David Zambrano
Membre depuis le 09/28/17
822 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S13-G4, Boczar Fall 2017 Membre de l'équipe USF Tampa, Team S13-G4, Boczar Fall 2017
USFT-BOCZAR-F17S13G4
4 membres
5 tutoriels rédigés
4 commentaires
Is this about the WiFi card? Because I cant see the SSD in any of your pictures.
Julian Lemmerich - Réponse
So, where is the SSD? You’ve taken apart the whole logic board, but not evidence of any SSD module from your photos….
Matteo Repossi - Réponse
It is not SSD drive, it is a motherboard
Da K - Réponse
has anyone figured out where is the SSD (eMMC) by the way ?
Karantez Jegou - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 28
Total : 7,473
