Aller au contenu principal
HP Pavilion x2 10-n113dx Battery Replacement
Ce dont vous avez besoin
  1. HP Pavilion x2 10-n113dx Battery Replacement, Battery: étape 1, image 1 de 3 HP Pavilion x2 10-n113dx Battery Replacement, Battery: étape 1, image 2 de 3 HP Pavilion x2 10-n113dx Battery Replacement, Battery: étape 1, image 3 de 3
    • Before starting, please turn off your laptop.
    • Using the blue plastic opening tool or a flat bladed tool, carefully slide the blade in between the display panel and gently slide to prop open the assembly.
  2. HP Pavilion x2 10-n113dx Battery Replacement: étape 2, image 1 de 2 HP Pavilion x2 10-n113dx Battery Replacement: étape 2, image 2 de 2
    • Gently lift and remove the display panel from the assembly.
    • Remove the translucent yellow tape that covers the battery connector on the mainboard.
    • The tape will be in the way for a future step.
  3. HP Pavilion x2 10-n113dx Battery Replacement: étape 3, image 1 de 3 HP Pavilion x2 10-n113dx Battery Replacement: étape 3, image 2 de 3 HP Pavilion x2 10-n113dx Battery Replacement: étape 3, image 3 de 3
    • Flip up the small white colored locking flap using the tip of a spudger or your fingernail. Then the ribbon cable can be removed easily without much effort.
    • Carefully disconnect the white ribbon cable from the mainboard.
  4. HP Pavilion x2 10-n113dx Battery Replacement: étape 4, image 1 de 3 HP Pavilion x2 10-n113dx Battery Replacement: étape 4, image 2 de 3 HP Pavilion x2 10-n113dx Battery Replacement: étape 4, image 3 de 3
    • Carefully disconnect the battery cable from its connector on the mainboard.
  5. HP Pavilion x2 10-n113dx Battery Replacement: étape 5, image 1 de 3 HP Pavilion x2 10-n113dx Battery Replacement: étape 5, image 2 de 3 HP Pavilion x2 10-n113dx Battery Replacement: étape 5, image 3 de 3
    • Using the Phillips #0 screwdriver, carefully remove the 4 corner screws that hold the battery to the display panel.
    • 3 screws are 3.12 mm head, 2.40 mm length, and 1 screw is 5.85mm head, 2.5mm length.
    • Remove the battery from the device.
4 autres ont terminé cette réparation.
David Zambrano
Membre depuis le 09/28/17
822 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S13-G4, Boczar Fall 2017 Membre de l'équipe USF Tampa, Team S13-G4, Boczar Fall 2017
USFT-BOCZAR-F17S13G4
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 40
Total : 5,012
