Aller au contenu principal
HP Pavilion x2 10-n113dx Hinge Replacement
Ce dont vous avez besoin
  1. HP Pavilion x2 10-n113dx Hinge Replacement, Hinge: étape 1, image 1 de 2 HP Pavilion x2 10-n113dx Hinge Replacement, Hinge: étape 1, image 2 de 2
    • Separate the screen from the keyboard.
  2. HP Pavilion x2 10-n113dx Hinge Replacement: étape 2, image 1 de 2 HP Pavilion x2 10-n113dx Hinge Replacement: étape 2, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Remove the grey rubber bar using plastic spudger or tweezers, exposing the four screw heads.
    • The rubber bar is attached with an adhesive. A heat pad may be required to melt the adhesive and allow for easier removal.
  3. HP Pavilion x2 10-n113dx Hinge Replacement: étape 3, image 1 de 1
    • Unscrew the four screws using the Phillips #0 screwdriver.
    • All four of these screws have a diameter of 4.3 mm and a height of 3.7 mm.
  4. HP Pavilion x2 10-n113dx Hinge Replacement: étape 4, image 1 de 2 HP Pavilion x2 10-n113dx Hinge Replacement: étape 4, image 2 de 2
    • Remove the circular rubber tabs exposing the screw heads below.
    • A heat pad may be required to melt the tab adhesive and allow for easier removal.
    • Unscrew the two screws using the Phillips #0 screwdriver.
    • These two screws are 5.3 mm in diameter and 4.3 mm in height.
  5. HP Pavilion x2 10-n113dx Hinge Replacement: étape 5, image 1 de 3 HP Pavilion x2 10-n113dx Hinge Replacement: étape 5, image 2 de 3 HP Pavilion x2 10-n113dx Hinge Replacement: étape 5, image 3 de 3
    • Once all screws have been removed, gently pry open the back casing using a metal spudger.
    • Be sure to use the spudger at the marked locations to avoid damage to the casing.
  6. HP Pavilion x2 10-n113dx Hinge Replacement: étape 6, image 1 de 2 HP Pavilion x2 10-n113dx Hinge Replacement: étape 6, image 2 de 2
    • Completely remove the back casing.
  7. HP Pavilion x2 10-n113dx Hinge Replacement: étape 7, image 1 de 1
    • Unscrew the four screws located at the marked locations using the Phillips #0 screwdriver.
    • All fours of these screws have a 7.0 mm diameter an a 2.5 mm height.
  8. HP Pavilion x2 10-n113dx Hinge Replacement: étape 8, image 1 de 1
    • Remove adhesive that secures the ribbon cable using tweezers.
  9. HP Pavilion x2 10-n113dx Hinge Replacement: étape 9, image 1 de 3 HP Pavilion x2 10-n113dx Hinge Replacement: étape 9, image 2 de 3 HP Pavilion x2 10-n113dx Hinge Replacement: étape 9, image 3 de 3
    • Using a plastic spudger, flip open the switch for the connection port, allowing the ribbon cable to be removed.
  10. HP Pavilion x2 10-n113dx Hinge Replacement: étape 10, image 1 de 3 HP Pavilion x2 10-n113dx Hinge Replacement: étape 10, image 2 de 3 HP Pavilion x2 10-n113dx Hinge Replacement: étape 10, image 3 de 3
    • Gently lift the hinge from the attachment points as shown in the picture.
    • Tweezers can be also be used to ensure the ribbon cable does not get damaged in the process.
    • The hinge can now be completely separated.
Ajay Panuganti
Membre depuis le 04/01/19
181 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S1-G4, Harley Spring 2019 Membre de l'équipe IUPUI, Team S1-G4, Harley Spring 2019
IUPUI-HARLEY-S19S1G4
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 13
Total : 1,124
