Aller au contenu principal
HP Pavilion x2 10-n113dx Touch Pad Replacement
Ce dont vous avez besoin
  1. HP Pavilion x2 10-n113dx Touch Pad Replacement, Touch Pad: étape 1, image 1 de 2 HP Pavilion x2 10-n113dx Touch Pad Replacement, Touch Pad: étape 1, image 2 de 2
    • Separate the screen from the keyboard.
  2. HP Pavilion x2 10-n113dx Touch Pad Replacement: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Loosen the adhesive under the gray plastic bar using a heat pad or a heat gun.
    • Remove the gray plastic bar after 5 minutes of light heat with tweezers by pulling up.
  3. HP Pavilion x2 10-n113dx Touch Pad Replacement: étape 3, image 1 de 1
    • Remove the 4 screws with a Phillips #0 screwdriver.
    • These 4 screws have a diameter of 4.3 mm and a height of 3.7 mm.
  4. HP Pavilion x2 10-n113dx Touch Pad Replacement: étape 4, image 1 de 2 HP Pavilion x2 10-n113dx Touch Pad Replacement: étape 4, image 2 de 2
    • Remove the rubber stoppers at the top left and right with tweezers.
    • Remove the screws at the top and right with at Phillips #0 screwdriver.
    • These two screws have a diameter of 5.3 mm and a height of 4.3 mm.
  5. HP Pavilion x2 10-n113dx Touch Pad Replacement: étape 5, image 1 de 3 HP Pavilion x2 10-n113dx Touch Pad Replacement: étape 5, image 2 de 3 HP Pavilion x2 10-n113dx Touch Pad Replacement: étape 5, image 3 de 3
    • Pry open the back case with a metal spudger.
    • Then pry open the back layer with the metal spudger.
  6. HP Pavilion x2 10-n113dx Touch Pad Replacement: étape 6, image 1 de 2 HP Pavilion x2 10-n113dx Touch Pad Replacement: étape 6, image 2 de 2
    • Fully take off the back panel by lifting up the panel.
  7. HP Pavilion x2 10-n113dx Touch Pad Replacement: étape 7, image 1 de 2 HP Pavilion x2 10-n113dx Touch Pad Replacement: étape 7, image 2 de 2
    • Pop open the ribbon cable piece on the touch pad with the blue plastic spudger.
    • Remove the ribbon cable with tweezers by pulling it out.
  8. HP Pavilion x2 10-n113dx Touch Pad Replacement: étape 8, image 1 de 2 HP Pavilion x2 10-n113dx Touch Pad Replacement: étape 8, image 2 de 2
    • Remove 4 screws with at Phillips #0 screwdriver. All 4 screws have a diameter of 4.3 mm and a height of 3.7 mm.
    • Lift the tape shown with orange boxes with tweezers.
    • Remove metal bar with a blue spudger.
  9. HP Pavilion x2 10-n113dx Touch Pad Replacement: étape 9, image 1 de 3 HP Pavilion x2 10-n113dx Touch Pad Replacement: étape 9, image 2 de 3 HP Pavilion x2 10-n113dx Touch Pad Replacement: étape 9, image 3 de 3
    • Lift up the touch pad by the metal edge with a blue plastic spudger.
    • Remove the touch pad from the computer.
Cayla Skaggs
Membre depuis le 04/01/19
337 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S1-G4, Harley Spring 2019 Membre de l'équipe IUPUI, Team S1-G4, Harley Spring 2019
IUPUI-HARLEY-S19S1G4
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 705
