Aller au contenu principal
HP Pavilion x360 11-p110nr Touchpad Replacement
Ce dont vous avez besoin
  1. HP Pavilion x360 11-p110nr Touchpad Replacement, Touchpad: étape 1, image 1 de 3 HP Pavilion x360 11-p110nr Touchpad Replacement, Touchpad: étape 1, image 2 de 3 HP Pavilion x360 11-p110nr Touchpad Replacement, Touchpad: étape 1, image 3 de 3
    • Eleven case screws are located on the bottom of the laptop. Two will be underneath the rubber feet.
    • Use a Phillips #0 screwdriver to remove all 6.7 mm screws from the bottom cover.
    • Once the screws are removed, carefully take the bottom plate off.
    • Don't force the bottom plate off. There will be a cable connecting the bottom plate to the rest of the laptop. If you pull too hard you risk damaging this cable.
  2. HP Pavilion x360 11-p110nr Touchpad Replacement: étape 2, image 1 de 3 HP Pavilion x360 11-p110nr Touchpad Replacement: étape 2, image 2 de 3 HP Pavilion x360 11-p110nr Touchpad Replacement: étape 2, image 3 de 3
    • Before fully removing the top cover, locate the cable that connects the audio controls.
    • Once located, lift the small black flap and carefully pull the cable out.
  3. HP Pavilion x360 11-p110nr Touchpad Replacement: étape 3, image 1 de 2 HP Pavilion x360 11-p110nr Touchpad Replacement: étape 3, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the five 6.7 mm screws that secure the battery.
    • Use a Phillips #0 screwdriver to remove the two 3.2 mm screws that secure the hard drive.
    • Locate the cable for the battery and the cable for the speakers and unplug those as well.
  4. HP Pavilion x360 11-p110nr Touchpad Replacement: étape 4, image 1 de 3 HP Pavilion x360 11-p110nr Touchpad Replacement: étape 4, image 2 de 3 HP Pavilion x360 11-p110nr Touchpad Replacement: étape 4, image 3 de 3
    • Once all screws are removed, carefully remove the battery and hard drive as one unit.
    • Caution: Lithium Ion batteries provide a risk of electrocution or fire if mishandled. Failure to disconnect the battery before removing the speakers could also lead to risk of electrocution.
  5. HP Pavilion x360 11-p110nr Touchpad Replacement: étape 5, image 1 de 1
    • Once the battery and hard drive are removed, you should be able to see the touchpad.
  6. HP Pavilion x360 11-p110nr Touchpad Replacement: étape 6, image 1 de 3 HP Pavilion x360 11-p110nr Touchpad Replacement: étape 6, image 2 de 3 HP Pavilion x360 11-p110nr Touchpad Replacement: étape 6, image 3 de 3
    • Find the cable for the touchpad and unplug it.
    • Remove and install carefully as to not damage the cable.
  7. HP Pavilion x360 11-p110nr Touchpad Replacement: étape 7, image 1 de 3 HP Pavilion x360 11-p110nr Touchpad Replacement: étape 7, image 2 de 3 HP Pavilion x360 11-p110nr Touchpad Replacement: étape 7, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the two 3.2 mm screws that secure the touchpad bracket.
    • Slowly lift up the bracket and remove it.
  8. HP Pavilion x360 11-p110nr Touchpad Replacement: étape 8, image 1 de 2 HP Pavilion x360 11-p110nr Touchpad Replacement: étape 8, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the three 2.35 mm screws that secure the touchpad.
    • Remove the cover holding the touchpad in place.
  9. HP Pavilion x360 11-p110nr Touchpad Replacement: étape 9, image 1 de 1
    • You can now remove and replace the trackpad.
    • Be careful not to scratch the screen during the replacement of the trackpad as the screen will be located directly underneath the trackpad.
Aeorrell
Membre depuis le 03/27/23
433 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team 1-2, Harley Spring 2023 Membre de l'équipe IUPUI, Team 1-2, Harley Spring 2023
IUPUI-HARLEY-S23S1G2
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 13
Total : 75
