Aller au contenu principal
HP Pavilion x360 11m-ad013dx Keyboard Replacement
Ce dont vous avez besoin
  1. HP Pavilion x360 11m-ad013dx Keyboard Replacement, Keyboard: étape 1, image 1 de 1
    • Lay the HP Pavilion top-down with the front edge facing towards you.
  2. HP Pavilion x360 11m-ad013dx Keyboard Replacement: étape 2, image 1 de 1
    • Remove the three 4.8mm Phillips #0 screws from the front side.
  3. HP Pavilion x360 11m-ad013dx Keyboard Replacement: étape 3, image 1 de 2 HP Pavilion x360 11m-ad013dx Keyboard Replacement: étape 3, image 2 de 2
    • Using a plastic spudger, remove the grey silicon strip closest to the back-side.
  4. HP Pavilion x360 11m-ad013dx Keyboard Replacement: étape 4, image 1 de 1
    • Remove the three 5.7mm Phillips #1 screws.
  5. HP Pavilion x360 11m-ad013dx Keyboard Replacement: étape 5, image 1 de 2 HP Pavilion x360 11m-ad013dx Keyboard Replacement: étape 5, image 2 de 2
    • Open the HP Pavilion so that the screen is showing. Then tilt it down so that the screen is on its back, facing up.
    • Using a spudger, pry off the black keyboard panel.
    • This step requires force to unclasp the latches keeping the keyboard in place.
  6. HP Pavilion x360 11m-ad013dx Keyboard Replacement: étape 6, image 1 de 2 HP Pavilion x360 11m-ad013dx Keyboard Replacement: étape 6, image 2 de 2
    • Using your fingernail, disconnect the zero insertion force (ZIF) keyboard connector cable by flipping up the small locking flap.
    • You may disconnect the other end of the cable, for ease of access to other parts. Keep in mind that the end labeled MB connects to the motherboard.
  7. HP Pavilion x360 11m-ad013dx Keyboard Replacement: étape 7, image 1 de 2 HP Pavilion x360 11m-ad013dx Keyboard Replacement: étape 7, image 2 de 2
    • Using your fingernail, disconnect the zero insertion force (ZIF) connector for the touch pad cable by flipping up the small locking flap.
  8. HP Pavilion x360 11m-ad013dx Keyboard Replacement: étape 8, image 1 de 1
    • Remove the keyboard.
Hank Ferguson
Membre depuis le 01/13/20
590 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 9
Total : 1,117
