Introduction
Use this guide to replace your battery in your HP Pavilion laptop.
Note: This guide is written for the HP Pavilion x360 14-ba253cl model.
Still under warranty? Contact HP to learn your warranty status, receive a repair under warranty if eligible, or for further warranty information.
This procedure requires removing the battery to disconnect it. Use care to avoid bending, twisting, or puncturing it—a charged lithium-ion battery can be very dangerous if accidentally punctured. If your battery looks puffy or swollen, take extra precautions.
Don't continue to use a damaged battery, as doing so is a potential safety hazard. If in doubt, replace it with a new battery.
Ce dont vous avez besoin
Raise the keyboard slightly to gain access to the touch pad and keyboard cables.
Using a spudger, lift up the plastic locks that connect the ribbon cable to the system board.
Use the blue plastic tab on the ribbon cable to pull it out from the system board.
Remove the keyboard from the laptop.
5 autres ont terminé cette réparation.
