Aller au contenu principal
HP Pavilion x360 14m-ba011dx Motherboard Replacement
Ce dont vous avez besoin
  1. HP Pavilion x360 14m-ba011dx Motherboard Replacement, Battery: étape 1, image 1 de 2 HP Pavilion x360 14m-ba011dx Motherboard Replacement, Battery: étape 1, image 2 de 2
    • Remove the top left and right rubber pads closest to the hinge of screen using a plastic spudger to expose the screws underneath.
    • Remove the following 6 screws from the bottom of the device using a Phillips #00 Screwdriver:​
    • Two 7.5 mm screws.
    • Three 5 mm screws.
    • One 6.5 mm screw.
  2. HP Pavilion x360 14m-ba011dx Motherboard Replacement: étape 2, image 1 de 1
    • Push into the two screw holes that were under the rubber pads with the screwdriver to pop the keyboard out just a little.
    • Do this with the screen open so that you do not damage the screen.
    • Do not remove keyboard all the way.
  3. HP Pavilion x360 14m-ba011dx Motherboard Replacement: étape 3, image 1 de 2 HP Pavilion x360 14m-ba011dx Motherboard Replacement: étape 3, image 2 de 2
    • Separate the keyboard from the rest of the device using a metal or plastic spudger around the edges.
    • Pull up gently just until you can see the cables attaching the keyboard to the motherboard.
    • Flip the small white flaps holding the cables to the motherboard open to unplug the cords.
  4. HP Pavilion x360 14m-ba011dx Motherboard Replacement: étape 4, image 1 de 2 HP Pavilion x360 14m-ba011dx Motherboard Replacement: étape 4, image 2 de 2
    • Remove the purple cable attaching the battery to the motherboard by flipping the black flap and pulling the cable out.
    • Remove seven 4 mm screws using a Phillips #00 Screwdriver.
  5. HP Pavilion x360 14m-ba011dx Motherboard Replacement: étape 5, image 1 de 1
    • Remove the battery by gently pushing battery up, then pulling.
  6. HP Pavilion x360 14m-ba011dx Motherboard Replacement, Motherboard: étape 6, image 1 de 2 HP Pavilion x360 14m-ba011dx Motherboard Replacement, Motherboard: étape 6, image 2 de 2
    • Unclip the 5 cables connecting the motherboard to the computer.
  7. HP Pavilion x360 14m-ba011dx Motherboard Replacement: étape 7, image 1 de 1
    • Remove ten 4 mm screws using a Phillips #00 screwdriver.
  8. HP Pavilion x360 14m-ba011dx Motherboard Replacement: étape 8, image 1 de 1
    • Gently remove the motherboard.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 30
Total : 1,160
