Introduction
With this guide, the user will be able to access the RAM and either remove or add more RAM cards to the HP Pavilion x360 14m-ba011dx laptop. More RAM cards might be needed for your computer to run higher memory programs. The HP pavilion x360 14m-ba011dx laptop comes from the factory with an 8GB RAM card, however, there are 2 slots available for extra RAM capability.
Ce dont vous avez besoin
Remove the top left and right rubber pads closest to the hinge of screen using a plastic spudger to expose the screws underneath.
Remove the following 6 screws from the bottom of the device using a Phillips #00 Screwdriver:
Two 7.5 mm screws.
Three 5 mm screws.
One 6.5 mm screw.
Separate the keyboard from the rest of the device using a metal or plastic spudger around the edges.
Pull up gently just until you can see the cables attaching the keyboard to the motherboard.
Flip the small white flaps holding the cables to the motherboard open to unplug the cords.
