Aller au contenu principal
HP Pavilion x360 14m-cd0003dx Fan Replacement
Ce dont vous avez besoin
  1. HP Pavilion x360 14m-cd0003dx Fan Replacement, Heat Sink and Fan: étape 1, image 1 de 1
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Fan Replacement: étape 2, image 1 de 2 HP Pavilion x360 14m-cd0003dx Fan Replacement: étape 2, image 2 de 2
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx Fan Replacement: étape 3, image 1 de 2 HP Pavilion x360 14m-cd0003dx Fan Replacement: étape 3, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the seven 5 mm screws that secure the fan and heatsink.
  4. HP Pavilion x360 14m-cd0003dx Fan Replacement: étape 4, image 1 de 1
    • Peel back the retention tape that secures the heat sink assembly.
  5. HP Pavilion x360 14m-cd0003dx Fan Replacement: étape 5, image 1 de 1
    • Disconnect the fan cable from the connector on the system board.
  6. HP Pavilion x360 14m-cd0003dx Fan Replacement: étape 6, image 1 de 1
    • Remove the heat sink assembly from the device.
2 autres ont terminé cette réparation.
Riley McMorrow
Membre depuis le 03/22/22
264 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 Membre de l'équipe UMass Dartmouth, Team 7-4, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G4
6 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 16
Total : 465
