Aller au contenu principal
HP Pavilion x360 14m-cd0003dx SSD Replacement
Ce dont vous avez besoin
  1. HP Pavilion x360 14m-cd0003dx SSD Replacement, SSD: étape 1, image 1 de 1
    • Make sure computer is turned off
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx SSD Replacement: étape 2, image 1 de 3 HP Pavilion x360 14m-cd0003dx SSD Replacement: étape 2, image 2 de 3 HP Pavilion x360 14m-cd0003dx SSD Replacement: étape 2, image 3 de 3
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx SSD Replacement: étape 3, image 1 de 2 HP Pavilion x360 14m-cd0003dx SSD Replacement: étape 3, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the 5 mm screw that secures the SSD.
  4. HP Pavilion x360 14m-cd0003dx SSD Replacement: étape 4, image 1 de 2 HP Pavilion x360 14m-cd0003dx SSD Replacement: étape 4, image 2 de 2
    • Peel back the black covering.
    • Pull out SSD.
Jack Benfeito
Membre depuis le 03/22/22
177 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 Membre de l'équipe UMass Dartmouth, Team 7-4, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G4
6 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 23
Total : 788
