Aller au contenu principal
HP Pavilion x360 14m-cd0003dx Touchpad Replacement
Ce dont vous avez besoin
  1. HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Battery: étape 1, image 1 de 1
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: étape 2, image 1 de 2 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: étape 2, image 2 de 2
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: étape 3, image 1 de 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: étape 3, image 2 de 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: étape 3, image 3 de 3
    • Remove the six 5 mm battery screws, and the battery can then be taken out.
  4. HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Touchpad: étape 4, image 1 de 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Touchpad: étape 4, image 2 de 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Touchpad: étape 4, image 3 de 3
    • Lift the black tab on the ZIF connector, and gently pull the track pad ribbon cable free.
  5. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: étape 5, image 1 de 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: étape 5, image 2 de 3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: étape 5, image 3 de 3
    • Use a Phillips Head Screwdriver to remove the bottom 3 screws (5 mm).
    • Remove the metal plate that secures the touch pad.
  6. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: étape 6, image 1 de 2 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: étape 6, image 2 de 2
    • Use a Phillips Head Screwdriver to unscrew top 3 screws (5 mm).
    • Remove touch pad.
Elijah Jope
Membre depuis le 03/22/22
379 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 Membre de l'équipe UMass Dartmouth, Team 7-4, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G4
6 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 13
Total : 380
