Aller au contenu principal
HP Pavilion x360 14m-cd0005dx Back Cover Replacement
Ce dont vous avez besoin
  1. HP Pavilion x360 14m-cd0005dx Back Cover Replacement, Back Cover: étape 1, image 1 de 1
    • Turn off and shut down the computer.
    • Disconnect the power adapter and all external devices connected to the computer.
    • Do not work with the device powered on. It may result in bodily harm through electric shock.
  2. HP Pavilion x360 14m-cd0005dx Back Cover Replacement: étape 2, image 1 de 1
    • Flip the device with the backplate up and with the hinge on the far side.
  3. HP Pavilion x360 14m-cd0005dx Back Cover Replacement: étape 3, image 1 de 2 HP Pavilion x360 14m-cd0005dx Back Cover Replacement: étape 3, image 2 de 2
    • Use the opening tool to remove the rubber feet attached to the bottom of the device.
  4. HP Pavilion x360 14m-cd0005dx Back Cover Replacement: étape 4, image 1 de 2 HP Pavilion x360 14m-cd0005dx Back Cover Replacement: étape 4, image 2 de 2
    • Remove all screws located on the bottom of the device:
    • Two Phillips #0 7.0mm screws
    • Three Phillips #00 4.5mm screws
    • Make sure to keep track of all screws removed from the device.
  5. HP Pavilion x360 14m-cd0005dx Back Cover Replacement: étape 5, image 1 de 3 HP Pavilion x360 14m-cd0005dx Back Cover Replacement: étape 5, image 2 de 3 HP Pavilion x360 14m-cd0005dx Back Cover Replacement: étape 5, image 3 de 3
    • Using the opening tool, carefully remove the bottom cover from the device.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 44
Total : 3,460
