Aller au contenu principal
HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement
Ce dont vous avez besoin
  1. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement, Back Cover: étape 1, image 1 de 1
    • Turn off and shut down the computer.
    • Disconnect the power adapter and all external devices connected to the computer.
    • Do not work with the device powered on. It may result in bodily harm through electric shock.
  2. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: étape 2, image 1 de 1
    • Flip the device with the backplate up and with the hinge on the far side.
  3. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: étape 3, image 1 de 2 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: étape 3, image 2 de 2
    • Use the opening tool to remove the rubber feet attached to the bottom of the device.
  4. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: étape 4, image 1 de 2 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: étape 4, image 2 de 2
    • Remove all screws located on the bottom of the device:
    • Two Phillips #0 7.0mm screws
    • Three Phillips #00 4.5mm screws
    • Make sure to keep track of all screws removed from the device.
  5. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: étape 5, image 1 de 3 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: étape 5, image 2 de 3 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: étape 5, image 3 de 3
    • Using the opening tool, carefully remove the bottom cover from the device.
  6. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement, Battery: étape 6, image 1 de 3 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement, Battery: étape 6, image 2 de 3 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement, Battery: étape 6, image 3 de 3
    • Use a #00 Phillips screwdriver to remove:
    • Six 2.5 mm screws
  7. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: étape 7, image 1 de 2 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: étape 7, image 2 de 2
    • Carefully lift from the base and remove the battery.
  8. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement, Heat Sink and Fan: étape 8, image 1 de 1
    • Remove the tape that secures the fan to the computer.
  9. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: étape 9, image 1 de 2 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: étape 9, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Find the fan cable
    • Use the Reverse Tweezers to unplug the fan cable
  10. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: étape 10, image 1 de 3 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: étape 10, image 2 de 3 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: étape 10, image 3 de 3
    • Remove all screws securing the fan to the device:
    • Two Phillips #00 4.5mm screws
    • Four Phillips #00 4.5mm screws
  11. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: étape 11, image 1 de 2 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: étape 11, image 2 de 2
    • Lift and remove the fan and heat sink from the device.
    • When removing the fan, there will be an adhesive strip attached to the bottom. There may be some resistance as the device is being removed. Use a spudger to hold the adhesive down during removal.
2 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 10
Total : 491
