Aller au contenu principal
HP Pavilion x360 m3-u001dx Battery Replacement
Ce dont vous avez besoin
  1. HP Pavilion x360 m3-u001dx Battery Replacement, Keyboard: étape 1, image 1 de 1
    • Shut down the computer.
    • Disconnect the power and all external devices connected to the computer.
    • Working on your device while it is turned on may result in electric shock.
  2. HP Pavilion x360 m3-u001dx Battery Replacement: étape 2, image 1 de 2 HP Pavilion x360 m3-u001dx Battery Replacement: étape 2, image 2 de 2
    • Use a Metal Spudger and remove the rubber foot closet from the bottom of the laptop.
  3. HP Pavilion x360 m3-u001dx Battery Replacement: étape 3, image 1 de 1
    • Remove all of the screws located on the bottom of the laptop:
    • 5 Phillips 2.4 x 5.7 mm screws
    • 5 Phillips 2.0 x 5.0 mm screws
    • Make special note of each screw and screw lock size and location during removal and replacement.
  4. HP Pavilion x360 m3-u001dx Battery Replacement: étape 4, image 1 de 1
    • Turn the computer over onto its base, with the computer open and the keyboard facing upward.
  5. HP Pavilion x360 m3-u001dx Battery Replacement: étape 5, image 1 de 2 HP Pavilion x360 m3-u001dx Battery Replacement: étape 5, image 2 de 2
    • The keyboard is attached internally by clips. Use a small amount of force when removing the keyboard.
    • Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
  6. HP Pavilion x360 m3-u001dx Battery Replacement: étape 6, image 1 de 1
    • Raise the keyboard slightly to access the touch pad and keyboard cables.
    • Raising the keyboard too far or with excessive force may cause damage to the keyboard, touch pad cables, or their connectors.
  7. HP Pavilion x360 m3-u001dx Battery Replacement: étape 7, image 1 de 1
    Outil utilisé dans cette étape :
    Heavy-Duty Spudger
    J'achète
    • Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
    • Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  8. HP Pavilion x360 m3-u001dx Battery Replacement: étape 8, image 1 de 1
    • Lift the keyboard away from the base of the laptop.
  9. HP Pavilion x360 m3-u001dx Battery Replacement, Battery: étape 9, image 1 de 1
    • Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
  10. HP Pavilion x360 m3-u001dx Battery Replacement: étape 10, image 1 de 1
    • Carefully lift the battery up from lower right corner and disconnect it from the motherboard.
Follow these instructions in reverse order to reassemble your device.
7 autres ont terminé cette réparation.
Subhleen
Membre depuis le 02/01/17
1 268 Réputation
5 tutoriels rédigés
Équipe
UW Tacoma, Team 1-6, Rose Winter 2017 Membre de l'équipe UW Tacoma, Team 1-6, Rose Winter 2017
UWT-ROSE-W17S1G6
4 membres
8 tutoriels rédigés
2 commentaires
Thanks for this easy step by step guide. The pictures were incredibly helpful!
azbeasleys - Réponse
I replaced the battery now the screen doesn't turn on. I plugged it into an external monitor and the computer works fine and even the touch aspect of the screen works, but it stays black. Did i accidentally disconnect something?
G Bates - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 7,308
