Aller au contenu principal
HP Pavilion x360 m3-u101dx Keyboard Panel Replacement
Ce dont vous avez besoin
  1. HP Pavilion x360 m3-u101dx Keyboard Panel Replacement, Keyboard Panel: étape 1, image 1 de 1
    • Flip the laptop over so that the bottom of the laptop is facing up.
  2. HP Pavilion x360 m3-u101dx Keyboard Panel Replacement: étape 2, image 1 de 1
    • Remove five 1.4mm Phillips #1 screws from the bottom of the laptop.
  3. HP Pavilion x360 m3-u101dx Keyboard Panel Replacement: étape 3, image 1 de 3 HP Pavilion x360 m3-u101dx Keyboard Panel Replacement: étape 3, image 2 de 3 HP Pavilion x360 m3-u101dx Keyboard Panel Replacement: étape 3, image 3 de 3
    • Remove the rubber grip using a plastic opening tool.
    • Remove five 1.7mm Phillips #1 screws.
  4. HP Pavilion x360 m3-u101dx Keyboard Panel Replacement: étape 4, image 1 de 3 HP Pavilion x360 m3-u101dx Keyboard Panel Replacement: étape 4, image 2 de 3 HP Pavilion x360 m3-u101dx Keyboard Panel Replacement: étape 4, image 3 de 3
    • Lift open the laptop screen and flip it around so that the keyboard is facing up.
    • Insert a plastic opening tool into one of the corners to create a gap between the bottom panel and the keyboard panel.
    • Guide the plastic opening tool around the perimeter of the panel to detach all the clips that are supporting it in place.
    • Do not pull the panel off by one corner as it can cause damage to the plastic.
    • Detach the keyboard panel from the frame.
    • There are two ribbon cables attached to the keyboard and trackpad so do not pull the keyboard panel away until you disconnect these ribbons in the next step.
  5. HP Pavilion x360 m3-u101dx Keyboard Panel Replacement: étape 5, image 1 de 3 HP Pavilion x360 m3-u101dx Keyboard Panel Replacement: étape 5, image 2 de 3 HP Pavilion x360 m3-u101dx Keyboard Panel Replacement: étape 5, image 3 de 3
    • Remove the two ribbon cables connected to the inside of the laptop by using a finger to lift up on the latches.
    • Remove the keyboard panel from the rest of the laptop.
Michael Rinaldi
Membre depuis le 01/22/20
217 Réputation
2 tutoriels rédigés
Équipe
York University, Team S8-G1, Turner Winter 2020 Membre de l'équipe York University, Team S8-G1, Turner Winter 2020
YORK-TURNER-W20S8G1
5 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 13
Total : 301
