Aller au contenu principal
HP Pavilion x360 m3-u103dx Fan Replacement
Ce dont vous avez besoin
  1. HP Pavilion x360 m3-u103dx Fan Replacement, Fan: étape 1, image 1 de 1
    • Power off device.
    • Flip laptop over.
  2. HP Pavilion x360 m3-u103dx Fan Replacement: étape 2, image 1 de 2 HP Pavilion x360 m3-u103dx Fan Replacement: étape 2, image 2 de 2
    • Remove the rubber foot with a Metal spudger
    • Remove 5 Phillip 2.4 x 5.7mm screws using a PH0 Phillips head screwdriver.
    • Remove 5 Phillips 2.8 x 5.0mm screws using a PH0 Phillips head screwdriver.
  3. HP Pavilion x360 m3-u103dx Fan Replacement: étape 3, image 1 de 3 HP Pavilion x360 m3-u103dx Fan Replacement: étape 3, image 2 de 3 HP Pavilion x360 m3-u103dx Fan Replacement: étape 3, image 3 de 3
    • Open computer and pry open keyboard panel using the Metal Spudger. Apply little pressure then increase until keyboard pops away from motherboard.
    • Gently lift keyboard on the mouse pad side. Remove three connected ribbon wires connecting keyboard to frame by gently disconnecting them from the motherboard.
  4. HP Pavilion x360 m3-u103dx Fan Replacement: étape 4, image 1 de 1
    • Remove eleven 2.0 x 4.6mm screws using the Phillips 00 Screwdriver
  5. HP Pavilion x360 m3-u103dx Fan Replacement: étape 5, image 1 de 3 HP Pavilion x360 m3-u103dx Fan Replacement: étape 5, image 2 de 3 HP Pavilion x360 m3-u103dx Fan Replacement: étape 5, image 3 de 3
    • Remove the motherboard gently from the base of the laptop.
    • Disconnect the fastened cables from the motherboard by carefully pushing the cable's plastic edges using the metal Spudger.
  6. HP Pavilion x360 m3-u103dx Fan Replacement: étape 6, image 1 de 2 HP Pavilion x360 m3-u103dx Fan Replacement: étape 6, image 2 de 2
    • Using the Phillips 00 Screw Driver. remove 4 screws from the heat sink.
    • Remove any adhesive tape. Detach the fan/heat sink.
2 autres ont terminé cette réparation.
Meaghan Hyatt
Membre depuis le 01/17/19
355 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 7
30 derniers jours : 16
Total : 1,327
