Aller au contenu principal
HP Pavilion x360 m3-u103dx RAM Replacement
Ce dont vous avez besoin
  1. HP Pavilion x360 m3-u103dx RAM Replacement, Keyboard: étape 1, image 1 de 1
    • Shut down the computer.
    • Disconnect the power and all external devices connected to the computer.
    • Working on your device while it is turned on may result in electric shock.
  2. HP Pavilion x360 m3-u103dx RAM Replacement: étape 2, image 1 de 2 HP Pavilion x360 m3-u103dx RAM Replacement: étape 2, image 2 de 2
    • Use a Metal Spudger and remove the rubber foot closet from the bottom of the laptop.
  3. HP Pavilion x360 m3-u103dx RAM Replacement: étape 3, image 1 de 1
    • Remove all of the screws located on the bottom of the laptop:
    • 5 Phillips 2.4 x 5.7 mm screws
    • 5 Phillips 2.0 x 5.0 mm screws
    • Make special note of each screw and screw lock size and location during removal and replacement.
  4. HP Pavilion x360 m3-u103dx RAM Replacement: étape 4, image 1 de 1
    • Turn the computer over onto its base, with the computer open and the keyboard facing upward.
  5. HP Pavilion x360 m3-u103dx RAM Replacement: étape 5, image 1 de 2 HP Pavilion x360 m3-u103dx RAM Replacement: étape 5, image 2 de 2
    • The keyboard is attached internally by clips. Use a small amount of force when removing the keyboard.
    • Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
  6. HP Pavilion x360 m3-u103dx RAM Replacement: étape 6, image 1 de 1
    • Raise the keyboard slightly to access the touch pad and keyboard cables.
    • Raising the keyboard too far or with excessive force may cause damage to the keyboard, touch pad cables, or their connectors.
  7. HP Pavilion x360 m3-u103dx RAM Replacement: étape 7, image 1 de 1
    • Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
    • Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  8. HP Pavilion x360 m3-u103dx RAM Replacement: étape 8, image 1 de 1
    • Lift the keyboard away from the base of the laptop.
  9. HP Pavilion x360 m3-u103dx RAM Replacement, Battery: étape 9, image 1 de 1
    • Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
  10. HP Pavilion x360 m3-u103dx RAM Replacement: étape 10, image 1 de 1
    • Carefully lift the battery up from lower right corner and disconnect it from the motherboard.
  11. HP Pavilion x360 m3-u103dx RAM Replacement, USB Port Shield: étape 11, image 1 de 3 HP Pavilion x360 m3-u103dx RAM Replacement, USB Port Shield: étape 11, image 2 de 3 HP Pavilion x360 m3-u103dx RAM Replacement, USB Port Shield: étape 11, image 3 de 3
    • (You don't NEED to remove this shielding as you can remove the board with it still there.)
    • Remove the adhesive strip.
    • Lift the shield away from the base of the laptop.
  12. HP Pavilion x360 m3-u103dx RAM Replacement, System Board (Motherboard): étape 12, image 1 de 3 HP Pavilion x360 m3-u103dx RAM Replacement, System Board (Motherboard): étape 12, image 2 de 3 HP Pavilion x360 m3-u103dx RAM Replacement, System Board (Motherboard): étape 12, image 3 de 3
    • Disconnect the ribbon cables attached to the system board (motherboard).
    • Use the plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  13. HP Pavilion x360 m3-u103dx RAM Replacement: étape 13, image 1 de 2 HP Pavilion x360 m3-u103dx RAM Replacement: étape 13, image 2 de 2
    • Disconnect the fastened cables from the system board (motherboard) by carefully pushing the cable's plastic edges using the Heavy Duty Spudger.
  14. HP Pavilion x360 m3-u103dx RAM Replacement: étape 14, image 1 de 2 HP Pavilion x360 m3-u103dx RAM Replacement: étape 14, image 2 de 2
    • Pull the clipped cables from system board (motherboard).
  15. HP Pavilion x360 m3-u103dx RAM Replacement: étape 15, image 1 de 3 HP Pavilion x360 m3-u103dx RAM Replacement: étape 15, image 2 de 3 HP Pavilion x360 m3-u103dx RAM Replacement: étape 15, image 3 de 3
    • Remove the system board (motherboard).
    • Using the Phillips 00 Screw Driver, remove 9 Phillips 2.0 x 4.7 mm screws with "M2L4" next to them.
    • Using the Phillips 00 Screw Driver, remove the silver screw.
  16. HP Pavilion x360 m3-u103dx RAM Replacement: étape 16, image 1 de 1
    • Carefully lift the front side of the system board (motherboard).
  17. HP Pavilion x360 m3-u103dx RAM Replacement: étape 17, image 1 de 1
    • Using a Heavy Duty Spudger, disconnect the black and red RTC battery cable on the left side of the system board (motherboard).
  18. HP Pavilion x360 m3-u103dx RAM Replacement: étape 18, image 1 de 1
    • Release the system board (motherboard) from the base enclosure.
    • Place the motherboard somewhere safe since it is the most delicate and expensive part of the laptop.
  19. HP Pavilion x360 m3-u103dx RAM Replacement, RAM: étape 19, image 1 de 2 HP Pavilion x360 m3-u103dx RAM Replacement, RAM: étape 19, image 2 de 2
    • Gently pry off the metal container holding the RAM.
  20. HP Pavilion x360 m3-u103dx RAM Replacement: étape 20, image 1 de 2 HP Pavilion x360 m3-u103dx RAM Replacement: étape 20, image 2 de 2
    • Push both tabs outward, so that the RAM pops up.
  21. HP Pavilion x360 m3-u103dx RAM Replacement: étape 21, image 1 de 2 HP Pavilion x360 m3-u103dx RAM Replacement: étape 21, image 2 de 2
    • Gently lift the RAM out of the socket, retaining the 30 degree angle it rests at.
Victor Samuel
Membre depuis le 01/08/15
199 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S2-G2, Wilson Summer 2019 Membre de l'équipe IUPUI, Team S2-G2, Wilson Summer 2019
IUPUI-WILSON-SU19S2G2
4 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 10
30 derniers jours : 24
Total : 2,616
