Aller au contenu principal
HP Pavilion zd8000 Keyboard Replacement
Ce dont vous avez besoin
  1. HP Pavilion zd8000 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Slide the battery release latch towards you.
  2. HP Pavilion zd8000 Keyboard Replacement: étape 2, image 1 de 2 HP Pavilion zd8000 Keyboard Replacement: étape 2, image 2 de 2
    • Pull up on the battery to remove it.
  3. HP Pavilion zd8000 Keyboard Replacement, Keyboard: étape 3, image 1 de 1
    • Remove the two 8mm Philips screws marked “K” on the bottom of the laptop.
  4. HP Pavilion zd8000 Keyboard Replacement: étape 4, image 1 de 2 HP Pavilion zd8000 Keyboard Replacement: étape 4, image 2 de 2
    • Flip the laptop over and open the screen.
    • Push up on the four latches located at the top of the keyboard with the spudger to release them.
  5. HP Pavilion zd8000 Keyboard Replacement: étape 5, image 1 de 2 HP Pavilion zd8000 Keyboard Replacement: étape 5, image 2 de 2
    • Lift the keyboard carefully because it is attached to the motherboard by a ribbon cable.
    • Lift the top of the keyboard towards you. Then, while keeping the keyboard at an angle, lift it towards the display.
  6. HP Pavilion zd8000 Keyboard Replacement: étape 6, image 1 de 2 HP Pavilion zd8000 Keyboard Replacement: étape 6, image 2 de 2
    • Rotate the keyboard so that the bottom is visible.
    • With the keyboard lifted, locate the blue-striped tab on the underside of the black ribbon cable.
    • Pull the tab towards you to release the keyboard from the laptop.
Allie Menard
Membre depuis le 04/12/11
820 Réputation
13 tutoriels rédigés
Équipe
Cal Poly, Team 24-56, Amido Spring 2011 Membre de l'équipe Cal Poly, Team 24-56, Amido Spring 2011
CPSU-AMIDO-S11S24G56
4 membres
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 14
Total : 4,096
