Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
Removing the RAM from this device is straightforward and requires little disassembly.
  1. Slide the battery release latch towards you.
    • Slide the battery release latch towards you.
  2. Pull up on the battery to remove it. Pull up on the battery to remove it.
    • Pull up on the battery to remove it.
  3. Loosen the Phillips screw labeled ‘ram’ and lift the cover. Loosen the Phillips screw labeled ‘ram’ and lift the cover.
    • Loosen the Phillips screw labeled ‘ram’ and lift the cover.
  4. Locate the green RAM card and find the metal tabs securing the card. Push outwards on the two tabs to release the card.
    • Locate the green RAM card and find the metal tabs securing the card.
    • Push outwards on the two tabs to release the card.
  5. Carefully slide the card out at an upward angle away from the slot.
    • Carefully slide the card out at an upward angle away from the slot.
3 autre(s) ont terminé cette réparation.
Allie Menard
Membre depuis le 12/04/2011
769 Réputation
13 tutoriels rédigés
Équipe
Cal Poly, Team 24-56, Amido Spring 2011 Membre de l'équipe Cal Poly, Team 24-56, Amido Spring 2011
CPSU-AMIDO-S11S24G56
4 membres
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 28
Total : 6,701
