Aller au contenu principal
HP Pavilion zd8000 Top Cover Replacement
Ce dont vous avez besoin
  1. HP Pavilion zd8000 Top Cover Replacement, Battery: étape 1, image 1 de 1
    • Slide the battery release latch towards you.
  2. HP Pavilion zd8000 Top Cover Replacement: étape 2, image 1 de 2 HP Pavilion zd8000 Top Cover Replacement: étape 2, image 2 de 2
    • Pull up on the battery to remove it.
  3. HP Pavilion zd8000 Top Cover Replacement, RAM: étape 3, image 1 de 2 HP Pavilion zd8000 Top Cover Replacement, RAM: étape 3, image 2 de 2
    • Loosen the Phillips screw labeled ‘ram’ and lift the cover.
  4. HP Pavilion zd8000 Top Cover Replacement: étape 4, image 1 de 2 HP Pavilion zd8000 Top Cover Replacement: étape 4, image 2 de 2
    • Locate the green RAM card and find the metal tabs securing the card.
    • Push outwards on the two tabs to release the card.
  5. HP Pavilion zd8000 Top Cover Replacement: étape 5, image 1 de 1
    • Carefully slide the card out at an upward angle away from the slot.
  6. HP Pavilion zd8000 Top Cover Replacement, WiFi Card Cables: étape 6, image 1 de 2 HP Pavilion zd8000 Top Cover Replacement, WiFi Card Cables: étape 6, image 2 de 2
    • Unscrew the four 8mm Philips screws marked with an icon resembling a stacks of discs.
    • Lift the cover from the right to remove it.
  7. HP Pavilion zd8000 Top Cover Replacement: étape 7, image 1 de 2 HP Pavilion zd8000 Top Cover Replacement: étape 7, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers to detach the grey and black cables connected to the green WiFi card.
  8. HP Pavilion zd8000 Top Cover Replacement, CD/Optical Drive: étape 8, image 1 de 1
    • Remove the 8mm Philips screw located between the hard drive and the WiFi card.
  9. HP Pavilion zd8000 Top Cover Replacement: étape 9, image 1 de 2 HP Pavilion zd8000 Top Cover Replacement: étape 9, image 2 de 2
    • Turn the laptop 90 degrees clockwise so you are facing the CD drive.
    • Unbend a paperclip and insert the end into the small hole by the eject button to cause the tray to pop out towards you.
  10. HP Pavilion zd8000 Top Cover Replacement: étape 10, image 1 de 2 HP Pavilion zd8000 Top Cover Replacement: étape 10, image 2 de 2
    • Gently pull the tray away from the laptop and the rest of the optical drive will follow.
  11. HP Pavilion zd8000 Top Cover Replacement, Keyboard: étape 11, image 1 de 1
    • Remove the two 8mm Philips screws marked “K” on the bottom of the laptop.
  12. HP Pavilion zd8000 Top Cover Replacement: étape 12, image 1 de 2 HP Pavilion zd8000 Top Cover Replacement: étape 12, image 2 de 2
    • Flip the laptop over and open the screen.
    • Push up on the four latches located at the top of the keyboard with the spudger to release them.
  13. HP Pavilion zd8000 Top Cover Replacement: étape 13, image 1 de 2 HP Pavilion zd8000 Top Cover Replacement: étape 13, image 2 de 2
    • Lift the keyboard carefully because it is attached to the motherboard by a ribbon cable.
    • Lift the top of the keyboard towards you. Then, while keeping the keyboard at an angle, lift it towards the display.
  14. HP Pavilion zd8000 Top Cover Replacement: étape 14, image 1 de 2 HP Pavilion zd8000 Top Cover Replacement: étape 14, image 2 de 2
    • Rotate the keyboard so that the bottom is visible.
    • With the keyboard lifted, locate the blue-striped tab on the underside of the black ribbon cable.
    • Pull the tab towards you to release the keyboard from the laptop.
  15. HP Pavilion zd8000 Top Cover Replacement, Switch Cover: étape 15, image 1 de 2 HP Pavilion zd8000 Top Cover Replacement, Switch Cover: étape 15, image 2 de 2
    • Place the laptop face-down and rotate it 180 degrees so the vents are facing you.
    • Remove the five 8mm Philips screws. Three are on the black base and two are near the hinges.
  16. HP Pavilion zd8000 Top Cover Replacement: étape 16, image 1 de 1
    • Flip the laptop over.
    • Fully open the laptop.
  17. HP Pavilion zd8000 Top Cover Replacement: étape 17, image 1 de 3 HP Pavilion zd8000 Top Cover Replacement: étape 17, image 2 de 3 HP Pavilion zd8000 Top Cover Replacement: étape 17, image 3 de 3
    • Rotate it so the display is on your right and the keyboard is on your left.
    • Lift the switch cover firmly but slowly so you do not snap it.
    • Lift the switch cover carefully from one end while sliding the spudger between the switch cover and the laptop to separate them.
    • The switch cover should easily separate from the laptop as you run the spudger through.
  18. HP Pavilion zd8000 Top Cover Replacement, Screen: étape 18, image 1 de 2 HP Pavilion zd8000 Top Cover Replacement, Screen: étape 18, image 2 de 2
    • Close the lid and rotate the laptop so that the vents are facing you.
    • Unscrew the two 8mm Philips screws below the hinges.
  19. HP Pavilion zd8000 Top Cover Replacement: étape 19, image 1 de 2 HP Pavilion zd8000 Top Cover Replacement: étape 19, image 2 de 2
    • Carefully rotate the laptop 90 degrees counter-clockwise and open the screen.
    • Pull on the black tab with the HP service sticker to unplug the display from the motherboard.
  20. HP Pavilion zd8000 Top Cover Replacement: étape 20, image 1 de 2 HP Pavilion zd8000 Top Cover Replacement: étape 20, image 2 de 2
    J'achète
    • Using tweezers, remove the black cable from the hole leading to the WiFi enclosure.
    • Pull gently to remove the black and grey cables from the case.
    • Check the surface beneath the laptop to ensure the cables do not catch on anything when you flip the laptop over.
  21. HP Pavilion zd8000 Top Cover Replacement: étape 21, image 1 de 2 HP Pavilion zd8000 Top Cover Replacement: étape 21, image 2 de 2
    • Using tweezers, pull the black cable towards the display and through the hole in the casing.
  22. HP Pavilion zd8000 Top Cover Replacement: étape 22, image 1 de 3 HP Pavilion zd8000 Top Cover Replacement: étape 22, image 2 de 3 HP Pavilion zd8000 Top Cover Replacement: étape 22, image 3 de 3
    • Unscrew the two 8mm Philips screws that attach the hinge to the laptop's display.
    • Lift the screen upwards to detach it from the laptop.
  23. HP Pavilion zd8000 Top Cover Replacement, Top Cover: étape 23, image 1 de 2 HP Pavilion zd8000 Top Cover Replacement, Top Cover: étape 23, image 2 de 2
    • With the laptop face-down, remove the eleven 8mm Philips screws.
  24. HP Pavilion zd8000 Top Cover Replacement: étape 24, image 1 de 2 HP Pavilion zd8000 Top Cover Replacement: étape 24, image 2 de 2
    • Rotate the laptop 180 degrees so the vents are facing you.
    • Unscrew the four 3mm Philips screws below the vents.
  25. HP Pavilion zd8000 Top Cover Replacement: étape 25, image 1 de 2 HP Pavilion zd8000 Top Cover Replacement: étape 25, image 2 de 2
    • Rotate the laptop 90 degrees counter-clockwise.
    • Unscrew the two 3mm Philips screws from the optical drive bay.
  26. HP Pavilion zd8000 Top Cover Replacement: étape 26, image 1 de 3 HP Pavilion zd8000 Top Cover Replacement: étape 26, image 2 de 3 HP Pavilion zd8000 Top Cover Replacement: étape 26, image 3 de 3
    • Flip the laptop over so it is face-up with the trackpad closest to you.
    • Locate the ribbon cable directly above the track pad.
    • Find the black latch at the end of the ribbon cable and unlatch it with a spudger to release it.
  27. HP Pavilion zd8000 Top Cover Replacement: étape 27, image 1 de 3 HP Pavilion zd8000 Top Cover Replacement: étape 27, image 2 de 3 HP Pavilion zd8000 Top Cover Replacement: étape 27, image 3 de 3
    • Find the ribbon cable on the LED board located at the top of the laptop.
    • You will notice that the ribbon cable is connected to two levels - you will be dealing with the one on the lower level.
  28. HP Pavilion zd8000 Top Cover Replacement: étape 28, image 1 de 2 HP Pavilion zd8000 Top Cover Replacement: étape 28, image 2 de 2
    J'achète
    • Locate the white connector attached to a red and black cable to the right of the LED board.
    • Using tweezers, pull the white connector away from you.
  29. HP Pavilion zd8000 Top Cover Replacement: étape 29, image 1 de 2 HP Pavilion zd8000 Top Cover Replacement: étape 29, image 2 de 2
    • Unscrew the four 8mm Philips screws from the top cover.
  30. HP Pavilion zd8000 Top Cover Replacement: étape 30, image 1 de 2 HP Pavilion zd8000 Top Cover Replacement: étape 30, image 2 de 2
    • Rotate the computer 90 degrees clockwise and insert the spudger at the seam above the card reader.
    • While lifting the front end of the top cover, slide the spudger across the seam.
    • When you have reached the firewire port, it should click open.
  31. HP Pavilion zd8000 Top Cover Replacement: étape 31, image 1 de 1
    • Lift the top cover from the left side to remove it completely.
2 autres ont terminé cette réparation.
Allie Menard
Membre depuis le 04/12/11
820 Réputation
13 tutoriels rédigés
Équipe
Cal Poly, Team 24-56, Amido Spring 2011 Membre de l'équipe Cal Poly, Team 24-56, Amido Spring 2011
CPSU-AMIDO-S11S24G56
4 membres
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 14
Total : 3,234
