Introduction
This guide is designed to replace the battery of the device: HP Pavilion ze5000. A replacement of a battery should occur if the laptop stops charging or is dead and will not respond to the device's charger. This guide can be used in case a device user wants to check the quality of the battery or replace the battery with a new battery installation. When completing this guide, ensure that the device is properly faced down with the back of the laptop facing the device user.
Push up on the arrow-shaped switch.
  • Push up on the arrow-shaped switch.
Ajouter un commentaire
While still holding the  switch up, remove the battery.
  • While still holding the switch up, remove the battery.
No reassembly in required once the new battery is in.
Gabrielle
Membre depuis le 19/03/2018
97 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S2-G7, Bernier Spring 2018 Membre de l'équipe UMass Dartmouth, Team S2-G7, Bernier Spring 2018
UMASSD-BERNIER-S18S2G7
3 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 21
