Aller au contenu principal
HP Pavilion ze5000 Primary Fan Replacement
Ce dont vous avez besoin
  1. HP Pavilion ze5000 Primary Fan Replacement, Battery: étape 1, image 1 de 1
    • Push up on the arrow-shaped switch.
  2. HP Pavilion ze5000 Primary Fan Replacement: étape 2, image 1 de 2 HP Pavilion ze5000 Primary Fan Replacement: étape 2, image 2 de 2
    • While still holding the switch up, remove the battery.
  3. HP Pavilion ze5000 Primary Fan Replacement, Keyboard: étape 3, image 1 de 3 HP Pavilion ze5000 Primary Fan Replacement, Keyboard: étape 3, image 2 de 3 HP Pavilion ze5000 Primary Fan Replacement, Keyboard: étape 3, image 3 de 3
    • Remove the two 5mm Phillips #0 screws from the hinges
  4. HP Pavilion ze5000 Primary Fan Replacement: étape 4, image 1 de 2 HP Pavilion ze5000 Primary Fan Replacement: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Open the device as if you were going to use the device. Using Tweezers, pry the hinges from underneath the screen
    • Not much force is needed to pull the hinges off once the tweezers are properly positioned
  5. HP Pavilion ze5000 Primary Fan Replacement: étape 5, image 1 de 2 HP Pavilion ze5000 Primary Fan Replacement: étape 5, image 2 de 2
    • Remove the wire connection by gently pulling on the fuse and connection itself.
    • Do not pull on the wires, as this can remove the wires from the connection, destroying the fuse.
  6. HP Pavilion ze5000 Primary Fan Replacement: étape 6, image 1 de 3 HP Pavilion ze5000 Primary Fan Replacement: étape 6, image 2 de 3 HP Pavilion ze5000 Primary Fan Replacement: étape 6, image 3 de 3
    • Remove the four 4.0 mm Phillips #0 connecting the keyboard to the frame
  7. HP Pavilion ze5000 Primary Fan Replacement: étape 7, image 1 de 2 HP Pavilion ze5000 Primary Fan Replacement: étape 7, image 2 de 2
    • Gently lift the keyboard up from the frame so that you can see the ribbon still connected.
  8. HP Pavilion ze5000 Primary Fan Replacement: étape 8, image 1 de 3 HP Pavilion ze5000 Primary Fan Replacement: étape 8, image 2 de 3 HP Pavilion ze5000 Primary Fan Replacement: étape 8, image 3 de 3
    • Remove the ribbon by gently pulling up the ends of the white receiver it is inserted in to.
    • You may need to use tweezers for this part.
    • During reassembly, when inserting the ribbon, you will hear a quiet, clicking sound when pushing down on the ends of the receiver. Hearing this ensures the ribbon is in place.
  9. HP Pavilion ze5000 Primary Fan Replacement, Primary Fan: étape 9, image 1 de 1
    • Remove sixteen 5.0 mm Phillips #1 screws from the underside of the device
  10. HP Pavilion ze5000 Primary Fan Replacement: étape 10, image 1 de 1
    • Remove the one 5.0 mm Phillips #1 screw underneath the battery home
  11. HP Pavilion ze5000 Primary Fan Replacement: étape 11, image 1 de 3 HP Pavilion ze5000 Primary Fan Replacement: étape 11, image 2 de 3 HP Pavilion ze5000 Primary Fan Replacement: étape 11, image 3 de 3
    • Remove the additional four 5.0 mm Phillips #1 screws from the hinge of the device
  12. HP Pavilion ze5000 Primary Fan Replacement: étape 12, image 1 de 2 HP Pavilion ze5000 Primary Fan Replacement: étape 12, image 2 de 2
    • Remove the two 4.0 mm Phillips #0 screws attached to the cicuit board above the keyboard
  13. HP Pavilion ze5000 Primary Fan Replacement: étape 13, image 1 de 1
    • Gently remove the disconnection to the right of the circuit board
  14. HP Pavilion ze5000 Primary Fan Replacement: étape 14, image 1 de 2 HP Pavilion ze5000 Primary Fan Replacement: étape 14, image 2 de 2
    • Take the circuit board off by pulling up on the right side of the circuit board
    • The board is plugged in to the device at this location still, but the outlet is hidden.
    • Pulling on the right side can snap the circuit board, so it is essential you pull on this side only
  15. HP Pavilion ze5000 Primary Fan Replacement: étape 15, image 1 de 2 HP Pavilion ze5000 Primary Fan Replacement: étape 15, image 2 de 2
    • Remove the five 5.0 mm Phillips #1 screws from underneath the keyboard
  16. HP Pavilion ze5000 Primary Fan Replacement: étape 16, image 1 de 3 HP Pavilion ze5000 Primary Fan Replacement: étape 16, image 2 de 3 HP Pavilion ze5000 Primary Fan Replacement: étape 16, image 3 de 3
    • Disconnect the ribbons from the circuit board underneath the keyboard housing unit
  17. HP Pavilion ze5000 Primary Fan Replacement: étape 17, image 1 de 3 HP Pavilion ze5000 Primary Fan Replacement: étape 17, image 2 de 3 HP Pavilion ze5000 Primary Fan Replacement: étape 17, image 3 de 3
    • Remove the connection beneath the left hinge of the device
  18. HP Pavilion ze5000 Primary Fan Replacement: étape 18, image 1 de 2 HP Pavilion ze5000 Primary Fan Replacement: étape 18, image 2 de 2
    • Pry the device apart to expose the inside of the device
    • This should be relatively easy since all connections and screws are removed. However, a spudger can be used if you are having difficulties.
  19. HP Pavilion ze5000 Primary Fan Replacement: étape 19, image 1 de 3 HP Pavilion ze5000 Primary Fan Replacement: étape 19, image 2 de 3 HP Pavilion ze5000 Primary Fan Replacement: étape 19, image 3 de 3
    • Remove the latches securing the fan housing unit by unscrewing the six 4.0 mm Phillips #0 screws
  20. HP Pavilion ze5000 Primary Fan Replacement: étape 20, image 1 de 1
    • Lift the housing unit a few inches from the device to expose the two small connections.
  21. HP Pavilion ze5000 Primary Fan Replacement: étape 21, image 1 de 2 HP Pavilion ze5000 Primary Fan Replacement: étape 21, image 2 de 2
    • Remove the two small connections directly above and below the fan housing unit
  22. HP Pavilion ze5000 Primary Fan Replacement: étape 22, image 1 de 2 HP Pavilion ze5000 Primary Fan Replacement: étape 22, image 2 de 2
    • Remove the fan housing unit and flip it over
  23. HP Pavilion ze5000 Primary Fan Replacement: étape 23, image 1 de 3 HP Pavilion ze5000 Primary Fan Replacement: étape 23, image 2 de 3 HP Pavilion ze5000 Primary Fan Replacement: étape 23, image 3 de 3
    • Remove the eight 3.5 mm Phillips #00 screws from the fan housing unit
  24. HP Pavilion ze5000 Primary Fan Replacement: étape 24, image 1 de 2 HP Pavilion ze5000 Primary Fan Replacement: étape 24, image 2 de 2
    • Remove both or whichever fan needs to be replaced
    • There should be bronze electric tape on the fan housing unit. Do not hesitate to tear the tape in order to open the housing unit
2 autres ont terminé cette réparation.
Eric Beaudry
Membre depuis le 03/06/18
823 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G7, Bernier Spring 2018 Membre de l'équipe UMass Dartmouth, Team S2-G7, Bernier Spring 2018
UMASSD-BERNIER-S18S2G7
2 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 234
