Aller au contenu principal
HP Pavilion ze5000 Screen Replacement
Ce dont vous avez besoin
  1. HP Pavilion ze5000 Screen Replacement, Screen: étape 1, image 1 de 3 HP Pavilion ze5000 Screen Replacement, Screen: étape 1, image 2 de 3 HP Pavilion ze5000 Screen Replacement, Screen: étape 1, image 3 de 3
    • Remove two 5.0 mm Philips #0 screws on the hinge of the device
  2. HP Pavilion ze5000 Screen Replacement: étape 2, image 1 de 2 HP Pavilion ze5000 Screen Replacement: étape 2, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Using tweezers, gently pull on the hinges to remove the plastic case connected to the hinges
  3. HP Pavilion ze5000 Screen Replacement: étape 3, image 1 de 3 HP Pavilion ze5000 Screen Replacement: étape 3, image 2 de 3 HP Pavilion ze5000 Screen Replacement: étape 3, image 3 de 3
    • Remove the connection between the plastic case and interior of the device
  4. HP Pavilion ze5000 Screen Replacement: étape 4, image 1 de 3 HP Pavilion ze5000 Screen Replacement: étape 4, image 2 de 3 HP Pavilion ze5000 Screen Replacement: étape 4, image 3 de 3
    • Remove the connection from the exposed hinge and interior of the device
  5. HP Pavilion ze5000 Screen Replacement: étape 5, image 1 de 2 HP Pavilion ze5000 Screen Replacement: étape 5, image 2 de 2
    • Remove the 3.5 mm philips #00 screw on the small circuit board on the hinge
  6. HP Pavilion ze5000 Screen Replacement: étape 6, image 1 de 2 HP Pavilion ze5000 Screen Replacement: étape 6, image 2 de 2
    • Remove the 5.0 mm philips #0 screw that was hidden underneath the small circuit board
  7. HP Pavilion ze5000 Screen Replacement: étape 7, image 1 de 1
    • Remove the 6 plastic caps located in the four corners of the screen and the top of the screen
    • It may be easier to use tweezers for this part
  8. HP Pavilion ze5000 Screen Replacement: étape 8, image 1 de 3 HP Pavilion ze5000 Screen Replacement: étape 8, image 2 de 3 HP Pavilion ze5000 Screen Replacement: étape 8, image 3 de 3
    • Unscrew the six 5.0 mm Philips #0 screws underneath the caps
  9. HP Pavilion ze5000 Screen Replacement: étape 9, image 1 de 3 HP Pavilion ze5000 Screen Replacement: étape 9, image 2 de 3 HP Pavilion ze5000 Screen Replacement: étape 9, image 3 de 3
    • Using a spudger, pry the plastic casing off of the screen.
  10. HP Pavilion ze5000 Screen Replacement: étape 10, image 1 de 3 HP Pavilion ze5000 Screen Replacement: étape 10, image 2 de 3 HP Pavilion ze5000 Screen Replacement: étape 10, image 3 de 3
    • Remove four 5.0 mm Philips #0 screws located in the corners of the screen
    • These screws locations will be close to the screws locations in step 2.
    • During reassembly, make sure you do not confuse the proper screw placements from this step and step 4.
  11. HP Pavilion ze5000 Screen Replacement: étape 11, image 1 de 2 HP Pavilion ze5000 Screen Replacement: étape 11, image 2 de 2
    • Remove the four 3.5 mm Philips #00 screws from the sides of the aluminum casing.
    • There will be two 3.5 mm Philips screws on each side
Eric Beaudry
Membre depuis le 03/06/18
823 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G7, Bernier Spring 2018 Membre de l'équipe UMass Dartmouth, Team S2-G7, Bernier Spring 2018
UMASSD-BERNIER-S18S2G7
2 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 148
