Aller au contenu principal
HP Pavilion zv5000 Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion zv5000 Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Make sure that your device is properly shut down and unplugged from any outlet.
    • Flip Pavilion over so that the bottom faces up and locate the battery in the bottom left corner.
  2. HP Pavilion zv5000 Hard Drive Replacement: étape 2, image 1 de 2 HP Pavilion zv5000 Hard Drive Replacement: étape 2, image 2 de 2
    • Press and slide up the battery release tab with your thumb until the battery pops out of place.
  3. HP Pavilion zv5000 Hard Drive Replacement: étape 3, image 1 de 2 HP Pavilion zv5000 Hard Drive Replacement: étape 3, image 2 de 2
    • Using two fingers, pry the rest of the battery out of the socket.
  4. HP Pavilion zv5000 Hard Drive Replacement, Hard Drive: étape 4, image 1 de 2 HP Pavilion zv5000 Hard Drive Replacement, Hard Drive: étape 4, image 2 de 2
    • Make sure that the Pavilion is completely powered down and unplugged. Failure to do so may result in an electrical shock.
    • Using the Phillips #0 screwdriver, unscrew the two Phillips PM 2.5X6.0mm screws.
    • The two screws do not come out of the hard drive assembly, they simply disconnect the assembly from the laptop.
  5. HP Pavilion zv5000 Hard Drive Replacement: étape 5, image 1 de 2 HP Pavilion zv5000 Hard Drive Replacement: étape 5, image 2 de 2
    • Place the spudger underneath the cover of the hard drive and push up gently until the hard drive pops out of place.
    • Completely remove the hard drive from its socket.
    • If the plastic spudger is not sturdy enough to pop the hard drive out of place, try carefully using the metal spudger.
Eliza Marks
Membre depuis le 10/18/16
649 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-6, Catania Fall 2016 Membre de l'équipe UMass Dartmouth, Team 4-6, Catania Fall 2016
UMASSD-CATANIA-F16S4G6
3 membres
5 tutoriels rédigés
Un commentaire
My hp pavilion zx5000 has a blue screen and i am unable to do anything. O. S. Is Windows.
Please help
Danny Morris - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 15
Total : 2,849
