Aller au contenu principal
HP Pavilion zv5000 Keyboard Replacement
Ce dont vous avez besoin
  1. HP Pavilion zv5000 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Make sure that your device is properly shut down and unplugged from any outlet.
    • Flip Pavilion over so that the bottom faces up and locate the battery in the bottom left corner.
  2. HP Pavilion zv5000 Keyboard Replacement: étape 2, image 1 de 2 HP Pavilion zv5000 Keyboard Replacement: étape 2, image 2 de 2
    • Press and slide up the battery release tab with your thumb until the battery pops out of place.
  3. HP Pavilion zv5000 Keyboard Replacement: étape 3, image 1 de 2 HP Pavilion zv5000 Keyboard Replacement: étape 3, image 2 de 2
    • Using two fingers, pry the rest of the battery out of the socket.
  4. HP Pavilion zv5000 Keyboard Replacement, Keyboard: étape 4, image 1 de 2 HP Pavilion zv5000 Keyboard Replacement, Keyboard: étape 4, image 2 de 2
    • Using a Phillips #0 screwdriver, unscrew all four Phillips PM 2.5X13.0mm screws and place in a secure area until the end of the project.
  5. HP Pavilion zv5000 Keyboard Replacement: étape 5, image 1 de 1
    • Flip laptop back over and open as far as it can go.
  6. HP Pavilion zv5000 Keyboard Replacement: étape 6, image 1 de 1
    • Use the flat edge of the plastic spudger inserted under the bottom of the strip cover and pry upwards to un-clip the cover, starting at the right and moving to the left.
    • If the plastic spudger is not doing the trick, try using the metal spudger careful to not pop any keys out.
  7. HP Pavilion zv5000 Keyboard Replacement: étape 7, image 1 de 2 HP Pavilion zv5000 Keyboard Replacement: étape 7, image 2 de 2
    • Use hands to completely lift off the strip cover and remove.
  8. HP Pavilion zv5000 Keyboard Replacement: étape 8, image 1 de 1
    • Use the Phillips #0 screwdriver again, unscrew all four Phillips PM 2.5X13.0mm screws from the top of the keyboard and set aside.
  9. HP Pavilion zv5000 Keyboard Replacement: étape 9, image 1 de 2 HP Pavilion zv5000 Keyboard Replacement: étape 9, image 2 de 2
    • Using your hands, lift the keyboard up from the top towards yourself until the keyboard is resting in your hand.
    • Do not aggressively pull at the keyboard for risk of ripping the connector cable.
  10. HP Pavilion zv5000 Keyboard Replacement: étape 10, image 1 de 2 HP Pavilion zv5000 Keyboard Replacement: étape 10, image 2 de 2
    • Gently slide out the connecting cable from the laptop to the keyboard.
    • Do not aggressively pull at the connecting cable.
  11. HP Pavilion zv5000 Keyboard Replacement: étape 11, image 1 de 1
    • Completely remove the keyboard from the rest of the laptop.
Eliza Marks
Membre depuis le 10/18/16
649 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-6, Catania Fall 2016 Membre de l'équipe UMass Dartmouth, Team 4-6, Catania Fall 2016
UMASSD-CATANIA-F16S4G6
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 11
Total : 848
